amana leaking grease on clothes
Grease is leaking from below the agitator..I assume the seal is bad...just wondering how to repair it and how much it will cost. Thanks
If the seal were bad you would see water leaking into the bottom. If there is grease leaking into the tub it is likely the transmission is the source and a replacement transmission or new machine will be required.
Take off the front and see what you can observe. Sorry for bad news. Let us know if you need more info. |
| All times are GMT -7. The time now is 01:52 PM. |
