| » Signature 2000 |
The water valve is bad and they are normally not expensive but you will need the model number to order. Washer Repair Guide
Quote:
Mfg. for Montgomery Ward Model # FFT-6589-80 Serial # 91J60756 09/91 A friend told me that if the valve is off to one side it is not too hard to replace, but if it is by the motor it will require more. Is there a way to discover which it is? Maybe a diagram or schematic? |
I tried this site and a few more and couldn’t find anything out for you. You will need to call a parts house such as this one and ask if they carry parts for this washer. As for where it is located on the washer I can’t tell you because I can’t look it up. If you have no luck finding anyone that carries parts for this washer remove the valve and take pictures of it and I will try to help you with a valve that may work as a replacement. I would hate to junk it just because the valve is bad as long as everything else works.
| Display Modes | |
| Montgomery ward signature 2000 compactor | jrw0918 | Trash Compactor Repair | 1 | 07-08-2009 09:06 AM |
| Ignitor for Signature 2000 Tappan | buffalova | Oven Repair (including Ranges and Cooktops) | 0 | 06-22-2009 06:18 AM |
| Squealing noise from Signature 2000 electric dryer | saumila | Dryer Repair | 1 | 02-14-2008 03:57 PM |
| Signature 2000 dryer won't shut off | CBB | Dryer Repair | 0 | 09-20-2007 02:03 PM |
