Discuss
loud washer in spin cycle
 in
Washer Repair
This washer makes a clanking or thumping sound whenever it speeds up in spin cycle no matter if there is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » loud washer in spin cycle
  #1 (permalink)
Old 02-20-2012, 08:41 PM
Junior Member
Dan111 is on a distinguished road
Default loud washer in spin cycle
Model Number: wfw9700vw01   Brand: Whirlpool   Age: 1 - 5 years
This washer makes a clanking or thumping sound whenever it speeds up in spin cycle no matter if there is clothes or no clothes in it. It sounds like it is coming from the drum somewhere. A serviceman came and looked at it and right away thought it was the rear bearing which was going to be $500 so he went ahead and replaced that but it didnt fix the problem so he came back and looked at it again and said it was one of the shocks so he put in 2 new shocks and said there would be no charge either he broke them putting in the bearing or he felt bad for us. This didnt fix the problem either. I cleaned out the drain deal and found nothing this has made this noise for about as long as we remember but kept getting worse in time. I had front cover off and top and doesnt sound like coming from drain pump or electric motor sounds like the inside drum itself but when he replaced rear bearing and had to change the whole rear drum I thought that would have eliminated that. There was a ding in the back panel that I popped back out with hammer but didnt notice it rubbing anywhere. Everything that I can see looks good. One other guys email u got sounded like the same situation and he ended up getting new washer and later on found out it was a coupler between motor and transmission but a couldn't find coupler on parts list but it was a different model. Anything you can think of that might help us out would be greatly appreciated we dont really want to junk it with it being only 2 years old and a $1200 unit. That serviceman said I would start looking 4 a new washer it works good though just loud when starts 2 spin fast which cant be good. If we need a new one we would like 2 hear an opinion on what to get we have a bad taste for front load but would like to still get somethin efficient maybe top load. Thanks for your time.
Dan
Ads By Google
Related Models
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
White Westinghouse WGF317ESB White Westinghouse/range
White Westinghouse WGF317ESC White Westinghouse/range
Frigidaire WGF321WADA Wwh(v1) / Gas Range
Frigidaire WGF321WADB Wwh(v1) / Gas Range
Frigidaire WGF321WAWA Wwh(v2) / Gas Range
Frigidaire WGF321WAWB Wwh(v2) / Gas Range
Frigidaire WGF323BADA Wwh(v3) / Gas Range
Frigidaire WGF323BADB Wwh(v1) / Gas Range
Frigidaire WGF323BADC Wwh(v1) / Gas Range
Frigidaire WGF323BADD Wwh(v1) / Gas Range
Frigidaire WGF323BADE Wwh(v1) / Gas Range
Frigidaire WGF323BAWA Wwh(v4) / Gas Range
Frigidaire WGF323BAWB Wwh(v2) / Gas Range
Frigidaire WGF323BAWC Wwh(v2) / Gas Range
Frigidaire WGF323BAWD Wwh(v2) / Gas Range
Frigidaire WGF323BAWE Wwh(v2) / Gas Range
Frigidaire WGF324BBDB Wwh(v0) / Gas Range
Frigidaire WGF324BBDC Wwh(v1) / Gas Range
Frigidaire WGF324BBWB Wwh(v0) / Gas Range
Frigidaire WGF324BBWC Wwh(v2) / Gas Range
Frigidaire WGF325BADA Wwh(v5) / Gas Range
Frigidaire WGF325BADB Wwh(v1) / Gas Range
Frigidaire WGF325BADC Wwh(v1) / Gas Range
Frigidaire WGF325BADD Wwh(v1) / Gas Range
Frigidaire WGF325BAWA Wwh(v6) / Gas Range
Frigidaire WGF325BAWB Wwh(v2) / Gas Range
  #2 (permalink)
Old 02-22-2012, 05:55 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If you have paid $500 for a repair you need to get the repair service back out there and fix it at no charge. If they will not cooperate call the BBB, and every consumer protection in your area. You paid big bucks for a repair, get it.
__________________
  #3 (permalink)
Old 02-22-2012, 07:13 PM
Junior Member
The buisness I bought the washer from covered the first bill $500 and the serviceman said that the bearing was bad even though it didn't fix the noise. The second thing he did was the two shocks and he told me that it was covered I'm guessing he paid for it since I still have the problem. So atleast I haven't had to pay anything yet the only problem is that I'm still stuck with a loud washer. The guy said he gives up and to shop for a new one. The noise is coming from the back part of drum somewhere. Nobody else around here works on front loads except for a place 60 miles away and they charge flat rate of $60 plus 1.50 per mile just to come and check it out or I can load it up and haul it there for $30 plus whatever it takes to fix it which probably isn't goin to be cheap. I'm pretty handy and would love to figure out the actual problem causing it but don't know if it's worth it or not. Our local appliance store is Western Auto and he would give me a loaner or sell me a new one for his cost he suggested cabrio cause he sells just whirlpool but I'm kinda sour on that brand. Especially when this one was so expensive. The store 60 miles away would delivery a new one and maybe give me somethin for this one depending on what they find with it. Then I could get a different brand. The problem is I haven't found hardly any with much for positive reviews. Any info or advice would be great thanks.
  #4 (permalink)
Old 02-23-2012, 04:55 AM
Senior Expert
APP Volunteer
Default
I still think the original repair person owes you a repair, it doesn't matter whether you or the dealer paid for it.
If you cannot get that serviceman to fix it for no cost then I would consider replacing it. For about $300 to $350 in our area you can get a good basic Whirlpool top loader, probably less if your local dealer will sell you one at cost.
I don't even have access to a service manual for your model, and the repair of the rear drum and the supports is what a good service person would do, so it may be the repair was bad, something was broken during the repair, or who knows.
Sometimes starting over is the best strategy.
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer loud spin cycle Mike57 Washer Repair 4 03-01-2013 08:39 AM
washer is very loud in spin cycle mlee Washer Repair 1 06-20-2011 08:43 AM
Washer has loud noise in spin cycle tonywh Washer Repair 5 11-18-2010 09:13 AM
Washer Spin Cycle Very Loud dradspin Washer Repair 4 07-02-2010 11:03 AM
washer loud spin cycle rottweiler Washer Repair 4 01-10-2010 09:09 AM
