Discuss
washer doesn't agitate or spin
 in
Washer Repair
The washer went out suddenly on a heavy load. I pulled off the front and the idler pulley, bearing and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer doesn't agitate or spin
  #1 (permalink)
Old 07-27-2009, 12:52 PM
Junior Member
resloan is on a distinguished road
Default washer doesn't agitate or spin
Model Number: N/A   Brand: Frigidaire   Age: More than 10 years
The washer went out suddenly on a heavy load. I pulled off the front and the idler pulley, bearing and pin were laying separately in the bottom. Belt OK. Looking closely at the idler pulley I can see a crack in the side. From the top I can turn the agitator CCW easily. CW requires I first turn ccw to a check and then turn CW. The tub moves with the agitator in either direction. Motor works. Is this a bad tranny?
Does this sound like a reasonable repair job? Or go for a new machine.
If a new one, any recommendations? (Having a bad back, wife needs a top load. I've looked at some reviews of newer machines and have seen a lot of bad reviews, hence thinking of trying to get a used older model.)
Ads By Google
Related Models
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
Norge N3177XRW Range - F/s Std Gas
Norge N3177XUA Range - F/s Std Gas
Norge N3177XUW Range - F/s Std Gas
Whirlpool N3257W0
Whirlpool N3257W1
Whirlpool N3257^0
Whirlpool N3257^1
Whirlpool N3357W0
Whirlpool N3357^0
Norge N3422PRA Range - S/c F/s Gas
Norge N3422PRW Range - S/c F/s Gas
Norge N3438SRA Range - S/c F/s Gas
Norge N3438SRW Range - S/c F/s Gas
Norge N3438VRV Range - S/c F/s Gas
Whirlpool N3457W0
Whirlpool N3457^0
Norge N3472SRA Range - S/c F/s Gas
Norge N3472SRW Range - S/c F/s Gas
Norge N3478VRV Range - S/c F/s Gas
Norge N3478VVV Range - S/c F/s Gas
Norge N3478XRA Range - S/c F/s Gas
Norge N3478XRW Range - S/c F/s Gas
Norge N3478XVA Range - S/c F/s Gas
Norge N3478XVW Range - S/c F/s Gas
Norge N3510KRA Range - F/s Std Ele
Norge N3510KRW Range - F/s Std Ele
Norge N3510PPA Range - F/s Std Ele
Norge N3510PPW Range - F/s Std Ele
Norge N3510PRA Range - F/s Std Ele
Norge N3510PRW Range - F/s Std Ele
Norge N3520SPA Range - F/s Std Ele
Norge N3520SPN Range - F/s Std Ele
Norge N3520SPW Range - F/s Std Ele
Norge N3520SRA Range - F/s Std Ele
Norge N3520SRW Range - F/s Std Ele
Norge N3521XPA Range - F/s Std Ele
Norge N3521XPW Range - F/s Std Ele
Norge N3521XRA Range - F/s Std Ele
Norge N3521XRW Range - F/s Std Ele
Norge N3832XRA Range - S/c F/s Ele
Norge N3832XRW Range - S/c F/s Ele
Norge N3875XRA Range - S/c F/s Ele
Norge N3875XRW Range - S/c F/s Ele
Norge N3878VRV Range - S/c F/s Ele
Norge N3878VVD Range - S/c F/s Ele
Norge N3878VVV Range - S/c F/s Ele
Norge N3878XRA Range - S/c F/s Ele
Norge N3878XRW Range - S/c F/s Ele
Norge N3878XVA Range - S/c F/s Ele
Norge N3878XVW Range - S/c F/s Ele
Magic Chef N40C-3-X9 Mwave - Cntrtp / Stand Alone
Norge N4231WRA Range - F/s Cont Clean Gas
Norge N4231WRW Range - F/s Cont Clean Gas
Norge N4251WTA Range - F/s Std Gas
Norge N4251WTW Range - F/s Std Gas
Whirlpool N9157L0
Whirlpool N9157L1
Whirlpool N9157X0
Whirlpool N9157^0
Whirlpool N9157^1
Whirlpool N9257L1
Whirlpool N9257L2
Whirlpool N9257X0
Whirlpool N9257X1
Whirlpool N9257^0
Whirlpool N9257^1
Whirlpool N9257^2
Whirlpool N9357L0
Whirlpool N9357L2
Whirlpool N9357L3
Whirlpool N9357^0
Whirlpool N9357^2
Whirlpool N9357^3
Whirlpool N9457L3
Whirlpool N9457X0
Whirlpool N9457X2
Whirlpool N9457X3
Whirlpool N9457X4
Whirlpool N9457X5
  #2 (permalink)
Old 07-28-2009, 12:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-28-2009, 01:10 PM
Junior Member
Default
The plate with this info (on top of control panel) is faded out. It was made in 1993, is extra-large capacity, 3/4 hp motor. Never a problem til now.
  #4 (permalink)
Old 07-28-2009, 08:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately without correct model number we are not able to find correct part numbers as well as break down diagrams. Guessing is not the way I would like to go.
Regarding a new washer I would recommend a top load machine made by Whirlpool without any electronics. Such washer, depends on capacity, can cost you between $350 to $500.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
Washer won't spin or agitate aprilfarmer Washer Repair 1 12-09-2009 05:17 PM
GE washer will not spin nor agitate Evans Washer Repair 1 05-19-2009 06:01 PM
washer won't spin or agitate cindyahouser Washer Repair 0 04-20-2009 02:34 PM
