Roper washer will not agitate or spin. Thought for sure it was the clutch/brake assembly so I replaced it. Problem still there. Hums through all cycles, fills and drains, no spin or agitation though.
could be direct coupler. Remove coupler and make sure little hole is not rounded out.
