Looking for the correct part. First time I ever took a washer apart.
Symtoms: Washer fills and drains will not agitate or spin Motor and belt are fine Can not move tub by hand Agitator will not move by hand able to turn motor and clutch one direction but will only turn 1/4 in the other direction then you hear a load clang (like metal hitting metal)
My first quess would be transmission...
Would you agree
I think your first guess is correct, I assume that you ran it with the front panel off and the belt off and the motor did just fine.
