Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Rubber gasket on Front Load Washer door (http://forum.appliancepartspros.com/washer-repair/42029-rubber-gasket-front-load-washer-door.html)
pbraley 07-26-2009 02:53 PM
I have a front load washer that needs new rubber gasket on door..it is
all mildewed. I have found out I can order a replacement part but my question is I was told by an appliance repair man that some have a chemical added that keeps the gasket from mildewing. I don't want to
buy one at $133 just to have it have this problem again. Also where are
instructions on how to replace this part.
richappy 07-26-2009 05:53 PM
The gasket comes with super glue to glue it to the panel. complete instructions come with the gasket. In a "sticky" above, they suggest you keep the door open when not in use. This is a rather easy job.
