After all the water drains during the cycle the washer just sits and won't start spinning. It hums like its trying. If you turn machine off and reset to drain and spin, sometimes starts right up other times it takes quite a few tries. It will eventually work.
I did the activation diagnostic test and the only fault code was F32, long drain. The drain hose and pump are not clogged and is running. Then I did the 5-min automatic test everything was cool up to C8. It would jump from C7 to C9. I ran it again and put it on C8 and it did not spin. I looked at test #3 the basket turns freely however I need to look into removing the console to access the machine/motor control to check the sensor.
