I replaced the 2 outer tub bearings, upper and lower, and the 2 other bearings, but the tub will not spin with one finger or even one hand. Should the upper and lower bearings be snug against the center spacer? The bearings would spin freely before I installed them. Can the covers be removed from those bearings? The spin more freely without. I have a new clutch, lid locks, control board, pressure switch etc; it all comes down to those freekin bearings. They cause the cycle to get stuck at 33 minutes. HELP please.
Sorry for the late reply I have been on other projects. Did your series FAV6800A us the Upper One-Way Bearing ring? If you remove the Clutch Pulley will the wash basket rotate in the the Outer Tub bearings? If you remove the Clutch Pulley and you still can't rotate the wash basket then we have something binding. Maybe over torqued the 1.75" Spinner Nut? ""Should the upper and lower bearings be snug against the center spacer?"" From my and other folks repair that spacer floats with some clearance between the Upper and Lower outer tub bearings. ""Can the covers be removed from those bearings?"" RS = Rubber Seal leave them in place.....6207-2RS. Did you follow this post? Dick
