| » Front Loader Washer Repair Help |
Model Number: MAH5500BWW Brand: Maytag Age: 5 - 10 years
How difficult is the installation of a Motor Control Assembly (Part #AP4027228 in a Maytag Neptune Front Load Washer? It is showing an error code of LR
& I am told that is the part that is needed. It does'nt completely fill/empty & I don't think it is spinning. Related Models |
Hi Donna
What you want to do is fairly easy, just take off the door, then the other two screws holding the front panel on and remove it. This will give you access to the motor control board. Here is the service manual which will show you how in detail. Your model is an updated version of the basic Neptune 3000. http://www.servicematters.com/maytag...s/16010061.pdf The supplement at the back is an update for your model. See page 4-5 for details on how to remove the board. Also, I suggest you do as much of the testing/troubleshooting as you can from the supplement to try to make certain the part you are replacing is the right fix, as it is pretty expensive. Good luck.
__________________
| Display Modes | |
| Looking for new front loader washer (easier to repair) | stevenc | Washer Repair | 2 | 12-24-2009 02:49 PM |
| Kenmore Front Loader Washer | hogmo | Washer Repair | 0 | 06-14-2009 04:46 AM |
| Whifrpool lock/door front loader washer repair | kchapell | Washer Repair | 1 | 05-30-2009 01:55 PM |
| washer front loader | fred m | Washer Repair | 2 | 05-13-2008 07:12 PM |
| front loader washer | Donald Belanger | Washer Repair | 4 | 12-07-2007 05:53 PM |
