My top loading Maytag neptune has this open door(od) error. It is a safety feature that makes you open the door between loades. The door locks during the cycles but then these switches pull in to unlock the door. I went online and saw posts that other people had the same problem. The "fix" was to jiggle these locks and it would work. This worked a couple of times and now it doesn't. Anyone have another suggestion?
