| » Washer died |
Model Number: lat8626aae Brand: Maytag Age: More than 10 years
Washer was working fine all morning. Then on one load, it filled just a bit then stopped filling. We manually turned the knob to other cylcles and they did not work. We checked the circuit breaker. We checked the outlet and it works. Is there anything else we can check. Being about 15 years old, is it worth paying minimum for $90 for a service call?
Most likely the problem is a bad lid switch.
The lid switch Part number: 12001908 Here are the breakdown diagrams and Replacement parts for Maytag LAT8626AAE WASHER-TOP LOADING | AppliancePartsPros.com Last edited by Simon / APP Team : 02-18-2012 at 05:16 PM. |
Our washer fills with the lid open or closed. So you are saying that if the switch is broken it won't fill with the lid in either position. Right?
We are not mechanically inclined. Is this a fairly easy thing to fix on our own? Last edited by janejacobs : 02-18-2012 at 05:35 PM. |
Sorry. I made a mistake. According to the serial number you need different lid switch which has the fuse. If the fuse is blown the water wont fill. If the fuse is open the most logical thing is to replace the lid switch assembly.
The lid switch Part number: AP4026359 It is located inside the control panel. Here are the breakdown diagrams and Replacement parts for Maytag LAT8626AAE WASHER-TOP LOADING | AppliancePartsPros.com |
| Display Modes | |
| ge profile dryer died at same time as washer | iamme | Dryer Repair | 0 | 01-16-2012 05:53 PM |
| ge profile washer died at same time as dryer | iamme | Washer Repair | 0 | 01-16-2012 05:43 PM |
| Maytag Performa Washer Died | CltGrl1377 | Washer Repair | 1 | 05-27-2009 06:20 PM |
| Maytag washer Died | maddyg | Dishwasher Repair | 8 | 09-03-2008 09:14 AM |
| Maytag Top load Washer died | TXwannabe | Washer Repair | 4 | 08-17-2008 07:26 PM |
