| » Dripping wet clothes |
Model Number: 23832 100 Brand: Kenmore Age: 1 - 5 years
Clothes are coming out of the washer still dripping with water. I have verified that there is no clog in the drain hose and that the "Agitate/Spin setting is set to normal (slow/fast). The switch clicks when I push in on it, what else should I be checking? Thank you.......Jeff
Hi Jeff
Open it up and take off the pump and check it out. Make sure it is not clogged or broken and is operating correctly. If your machine is spinning at the right speed and there is no problem with the pump/drain system the clothes have to spin semi dry If you need more info please post your full model number and the results of your pump inspection. Good luck
__________________
| Display Modes | |
| Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu | yzhong | Washer Repair | 3 | 09-22-2009 09:35 AM |
| Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu | yzhong | Washer Repair | 0 | 08-26-2009 02:18 PM |
| Maytag clothes washer, new pump and belt replaced, clothes wet after spin, more quest | yzhong | Washer Repair | 1 | 07-21-2009 02:41 AM |
| Maytag clothes washer, with new pump and belt, clothes were still too wet after s | yzhong | Washer Repair | 1 | 05-04-2009 03:21 PM |
| Maytag clothes washer, with pump and belt replaced in Nov. 2007, clothes were too wet | yzhong | Washer Repair | 1 | 04-22-2009 01:10 PM |
