Discuss
The little Neptune that couldn't
 in
Washer Repair
Hi, I'm having a problem with my Maytag front loading washer, it will make some sounds but water will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » The little Neptune that couldn't
  #1 (permalink)
Old 01-07-2008, 09:41 PM
konbit konbit is offline
Junior Member
konbit is on a distinguished road
Unhappy The little Neptune that couldn't
Model Number: MHW2000AWW   Brand: Maytag   Age: 5 - 10 years
Hi, I'm having a problem with my Maytag front loading washer, it will make some sounds but water will not come into the tub at the begining of thwe wash cycle. I tried the rinse cycle out some water came into the tub but the washer would cut off after about a 30-60 seconds .
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-08-2008, 09:51 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check the water inlet valve, the water pressure switch and the main board as described in the service manual.
- The part number for the main control board is AP3672790
- The part number for the water inlet valve is AP251181
- The part number for the water pressure switch is AP4026822
- Here are the break down diagrams fro the Maytag Neptune stackable washer/dryer Model MHW2000AWW
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune wont spin Stokes Washer Repair 0 12-15-2007 12:59 PM
Neptune Washer won't agitate or spin birdy Washer Repair 1 12-03-2007 01:23 PM
Sensor on Neptune gas dryer charliew Dryer Repair 1 09-30-2007 11:59 PM
Maytag Neptune LarryC Washer Repair 2 09-29-2007 08:56 PM
Maytag Neptune Washer utep42 Washer Repair 1 08-31-2007 04:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
