Discuss
Maytag Performa washer snubber replacement
 in
Washer Repair
The six springs hold the tub down snug to the snubber / base! they have to come off in order
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Performa washer snubber replacement
  #11 (permalink)
Old 02-13-2009, 02:47 PM
Junior Member
bad*dawg is on a distinguished road
Talking Spring....NO NO!
The six springs hold the tub down snug to the snubber / base! they have to come off in order to get the tub out so you can work on it.....The 200 lb tension compression spring on the brake is a whole different ball game. Once you get the tub / transmission out and upside down you will see (I think EIGHT) 5/16" hex head screws holding a plate / brake assembly / spring in place.(this plate also holds the snubber in place) I didn't screw with my brake but it seems you DO have to remove the pully to get the plate off so you can replace the brake. The screws MAY be long enough to release presure on the spring if you brack them out leaving a few threads in the base. If there still seems to be tension I would suggest replacing three or four of the screws with longer ones. Seems like they are 8/32 then continue backing them off until there's nothing pressing out on the plate suggesting there is still presure on it.
The second one you replace will go faster!!!!
  #12 (permalink)
Old 02-13-2009, 06:09 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
When you loosen all the screws on the brake housing, you will release the tension on the internal spring. On the performa, the screws should be long enough to do it.
__________________
  #13 (permalink)
Old 02-14-2009, 05:42 AM
Junior Member
chrisbanks00 is on a distinguished road
Default
Quote:
So when I replace my Brake rotor, lining, and brake stator I will only need to loosen all the screws on the brake housing? I do have a Performa, PAV3300AWW to be exact.
  #14 (permalink)
Old 02-14-2009, 08:27 AM
Junior Member
Default Replacing the brake
While I didn't piddle with my brake I would imagine the pully, all the screws, AND the plate / spring have to be removed. The lineing has to be above the spring.
  #15 (permalink)
Old 02-14-2009, 04:28 PM
Junior Member
Default
This should be fun. I'm going to try this without the brake tool. Wish me luck.
  #16 (permalink)
Old 02-15-2009, 02:07 AM
Senior Expert
APP Volunteer
Default
As long as you no NOT remove the pulley, you will be ok. The pulley will stop the housing from springing out all the way. In case the screws are too short, the only real problem will be it'l be harder to get it back together.
If you are concerned, I would just buy and use the longer screws.
__________________
  #17 (permalink)
Old 02-20-2009, 07:11 AM
Junior Member
Exclamation Snubber
Thought there were replies to your question but don't see them today. No the springs that hold down force between the tub and snubber are / is not the same as the spring that creates brake force.
  #18 (permalink)
Old 02-23-2009, 05:25 AM
Junior Member
Default
This weekend I replaced the snubber and the brakes. I must say this was all much easier then I was anticipating. The entire job took about an hour. First off, the brake and spring removal tool would have been a complete waste of money. With two of doing this, one person simply pressed down so the screws would reach. The only tricky part was putting the little clip back on towards the end. But even that wasn't that hard. Simply take a flat head screwdriver and pull it up just enough to slide the clip on.
What would have probably been a $200+ fix if we called the Maytag man ended cost about $25 in parts including shipping ordered from this site. Thanks guys!
  #19 (permalink)
Old 02-23-2009, 05:43 AM
Junior Member
Thumbs up Performa snubber
"one person simply pressed down so the screws would reach. The only tricky part was putting the little clip back".
Great all went well for you. Don't understand what you pressed down on so the screws would reach means and surprised the six springs didn't give you some trouble but I agree a tool would be a total wast of money. I take it you did remove the pulley which I've now read isn't necessary for replacing just the snubber.
  #20 (permalink)
Old 02-23-2009, 06:11 AM
Senior Expert
APP Volunteer
Default
Good work guys and thanks for the feedback.
In retrospect, using the longer 8-32 screws would have made the job easier.
Also, I understand that putting a weight on top of the agitator will make it easier to get the last washer and clip back on the pulley.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa will not wash after changing snubber bluvulture Washer Repair 3 07-17-2011 01:12 PM
Maytag Performa washer Cujok Washer Repair 1 01-25-2009 04:18 PM
Amana Washer - Snubber replacement 5GMs Washer Repair 13 11-29-2008 02:22 PM
Snubber Replacement on Frigidaire Washer skylarbeach Washer Repair 1 05-23-2008 07:49 PM
