Discuss
Spin cycle drains, but doesn't spin (Frigidaire Affinity)
 in
Washer Repair
I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spin cycle drains, but doesn't spin (Frigidaire Affinity)
  #1 (permalink)
Old 02-17-2012, 09:44 AM
Junior Member
tsteinruck is on a distinguished road
Default Spin cycle drains, but doesn't spin (Frigidaire Affinity)
Model Number: LTF7000ES0   Brand: Frigidaire   Age: 1 - 5 years
I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at the end "spin mode", it will not spin. The drain works fine. I called Appliance Parts Pro's and the parts specialist recommended part number 137007000 (control board), stating that was a common problem for my model number. After installing the new control board, there is no change. Is the new board bad, or just a bad guess. Thanks.
Ads By Google
Related Models
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
Whirlpool LVA5565W0
Whirlpool LVA5565W1
Whirlpool LVA6300W0
Whirlpool LVA6304W0
Whirlpool LVA6305W0
Whirlpool LVA6309W0
Whirlpool LVA6400W0
Whirlpool LVA6400W1
Whirlpool LVA6404W0
Whirlpool LVA6404W1
Whirlpool LVA6405W0
Whirlpool LVA6405W1
Whirlpool LVA6409W0
Whirlpool LVA6409W1
Whirlpool LVA6460W0
Whirlpool LVA6465W0
Whirlpool LVA6600W0
Whirlpool LVA6600W1
  #2 (permalink)
Old 02-17-2012, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did it show any error codes?
Run the Diagnostic test as described in the attached file and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire LTF7000ES0 Frigidaire/washer | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-18-2012, 07:25 AM
Junior Member
Default
Thank you for the reply. There were no error codes until I ran the diagnostic check you provided. All tests ran as described and E47 appeared at end.
  #4 (permalink)
Old 02-19-2012, 12:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This error code means: "Board thinks the door PTC circuit is open in spin". Most likely the problem is a bad door lock. You can find more useful information in one of our previous threads: frigidaire washer won't spin out!!
- The door lock assembly Part number: AP4455026
__________________
  #5 (permalink)
Old 04-21-2012, 11:11 AM
Junior Member
kpatrick is on a distinguished road
Default Patsy
This did the trick. I took out the old door lock. Took it to my local appliance parts house. Put it in and less than an hour I'm washing clothes.
Thanks, this really worked...
  #6 (permalink)
Old 04-23-2012, 02:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We are glad it did work for you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire affinity washer barrel will not spin out, drains fine prissy1000 Washer Repair 1 03-06-2011 04:26 AM
Frigidaire Gallery Series Won't Spin On Spin Cycle mosler Washer Repair 1 11-24-2010 02:13 PM
spin cycle drains but will not spin dionnem1 Washer Repair 1 12-22-2009 04:24 PM
Spin Dry Cycle - Washer drains but tub doesn't spin JARG Washer Repair 3 11-23-2009 09:22 AM
Pump Drains Tub But No Spin Cycle matt b Washer Repair 2 09-26-2007 04:51 AM
