Discuss
Setting dial problem
 in
Washer Repair
First, no actual clue on how old this is. Was bought used, and even if I can't repair the thing,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Setting dial problem
  #1 (permalink)
Old 02-16-2012, 10:47 AM
Junior Member
kittyn is on a distinguished road
Default Setting dial problem
Model Number: LSQ9600LG0   Brand: Whirlpool   Age: 1 - 5 years
First, no actual clue on how old this is. Was bought used, and even if I can't repair the thing, I'd say I've gotten my moneys worth by avoiding the laundromat for the past 16 months or so.
On to the issue: The settings dial to select wash type/length etc on the machine doesn't 'catch' to change settings. the knob will spin freely instead of actually moving the selecting arrow. It will let me pull the knob out and start the cycle it's currently on (broke about the final spin on 'gentle' while I was rotating it to start a load). It just seems like the knob does not catch the disk to change the setting. Any ideas on what/where is broke and if I can replace whatever it is myself would be appreciated.
Ads By Google
Related Models
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
Whirlpool LSQ9650PW0 Automatic Washer
Whirlpool LSQ9650PW1 Automatic Washer
Whirlpool LSQ9650PW2 Automatic Washer
Whirlpool LSQ9650PW3 Automatic Washer
Whirlpool LSQ9650PW4 Automatic Washer
Whirlpool LSQ9659LG0
Whirlpool LSQ9659LG1 Automatic Washer
Whirlpool LSQ9659LW0
Whirlpool LSQ9659LW1 Automatic Washer
Whirlpool LSQ9659PG0 Automatic Washer
Whirlpool LSQ9659PG1 Automatic Washer
Whirlpool LSQ9659PG2 Automatic Washer
Whirlpool LSQ9659PG3 Automatic Washer
Whirlpool LSQ9659PG4 Automatic Washer
Whirlpool LSQ9659PW0 Automatic Washer
Whirlpool LSQ9659PW1 Automatic Washer
Whirlpool LSQ9659PW2 Automatic Washer
Whirlpool LSQ9659PW3 Automatic Washer
Whirlpool LSQ9659PW4 Automatic Washer
Whirlpool LSQ9660PG0 Automatic Washer
Whirlpool LSQ9660PG1 Automatic Washer
Whirlpool LSQ9660PG2 Automatic Washer
Whirlpool LSQ9660PG3 Automatic Washer
Whirlpool LSQ9660PG4 Automatic Washer
Whirlpool LSQ9660PW0 Automatic Washer
Whirlpool LSQ9660PW1 Automatic Washer
Whirlpool LSQ9660PW2 Automatic Washer
Whirlpool LSQ9660PW3 Automatic Washer
Whirlpool LSQ9660PW4 Automatic Washer
Whirlpool LSQ9665JQ0
Whirlpool LSQ9665JQ1
Whirlpool LSQ9665JQ2
Whirlpool LSQ9665JQ3
Whirlpool LSQ9665JQ4
Whirlpool LSQ9665JT0
Whirlpool LSQ9665JT1
Whirlpool LSQ9665JT2
Whirlpool LSQ9665JT3
Whirlpool LSQ9665JT4
Whirlpool LSR4100HQ0
Whirlpool LSR4311DQ0
Whirlpool LSR5100HQ0
Whirlpool LSR5100KQ0
Whirlpool LSR5100LQ0
Whirlpool LSR5101LQ0
Whirlpool LSR5101LQ1 Automatic Washer
Whirlpool LSR5102LQ1 Automatic Washer
Whirlpool LSR5121HQ0
Whirlpool LSR5121JQ0
Whirlpool LSR5132AG0
Whirlpool LSR5132AN0
Whirlpool LSR5132AW0
Whirlpool LSR5132HQ0
Whirlpool LSR5132HQ1
Whirlpool LSR5132JQ0
Whirlpool LSR5132JQ2
Whirlpool LSR5132PQ0 Automatic Washer
Whirlpool LSR5132PQ1 Automatic Washer
Whirlpool LSR5132PQ3 Automatic Washer
Whirlpool LSR5132PQ4 Automatic Washer
Whirlpool LSR5232DW0
Whirlpool LSR5232LQ0
Whirlpool LSR5232LQ1 Automatic Washer
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0
Whirlpool LSR5233EQ0
Whirlpool LSR5233EQ1
Whirlpool LSR5233EQ2
Whirlpool LSR6132BN0
Whirlpool LSR6132BW0
Whirlpool LSR6132BW1
Whirlpool LSR6132DQ0
Whirlpool LSR6132DZ0
Whirlpool LSR6132EQ0
Whirlpool LSR6132EQ1
Whirlpool LSR6132EZ0
Whirlpool LSR6132EZ1
Whirlpool LSR6132HQ0
Whirlpool LSR6132HQ1
Whirlpool LSR6132HZ0
Whirlpool LSR6232JQ0
Whirlpool LSR6232JQ1
Whirlpool LSR6232JQ2 Automatic Washer
Whirlpool LSR6233BG0
Whirlpool LSR6233BN0
Whirlpool LSR6233BN1
Whirlpool LSR6233BW0
Whirlpool LSR6233BW1
Whirlpool LSR6233DN0
Whirlpool LSR6233DW0
Whirlpool LSR6244AG0
Whirlpool LSR6244AN0
Whirlpool LSR6244AW0
Whirlpool LSR6332KQ0
Whirlpool LSR6332KQ1 Automatic Washer
Whirlpool LSR6334LQ0
  #2 (permalink)
Old 02-16-2012, 01:59 PM
Junior Member
Default
ok, scratch that.
Further searching by myself means I figured out that its probably just the dial thing. But I cannot for the life of me figure out how to get it, and the knob, off. It doesn't screw off from the front, and everything I can find says that if it doesn't there should be a small black clip holding it on from the rear inside the panel. There is no clip, I can just see the end of what I'm assuming is a screw/bolt type thing (small, round, flat, and metal).
  #3 (permalink)
Old 02-17-2012, 02:19 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your timer shaft plastic end is stripped off, you need a new timer AP302050510. You can verify by taking the timer apart. To unscew the knob, you will need to use needle nose pliers to grab the shaft while turning the knob counterclockwise.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis washer-dial problem? pldepper Washer Repair 1 06-16-2011 07:10 PM
No heat and setting dial does not turn TOG1 Dryer Repair 4 07-06-2009 09:33 PM
Dishwasher Dial Problem Gary Lee Washer Repair 6 05-28-2009 11:01 AM
kenmore oven not heating to dial setting kings113 Oven Repair (including Ranges and Cooktops) 0 12-14-2008 06:17 PM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
