smbokanyi
#1 Posted : Thursday, February 16, 2012 9:29:29 AM(UTC)
smbokanyi
Hello,
I have LG WM2277hw washing machine, here’s the problem: When I turn it on to wash I get high pitch singing from the stator assemble and it does turn but it’s very jerky, until the power is removed from the coils thru the psb,, then it rotors very smooth, it seems only to turn in cw direction looking from the back. I checked the resistance on all three legs and get 8.2 ohms, and center tap where all three wire are tighten together to the three legs are 4.1ohms. I removed the Rotor Assembly, of course it didn’t move but I heard the same noise, also the very bottom coil and the one 180 degrees didn’t produce a magnet field? I removed the cover over the main PCB didn’t have burned smell it. Usually when you lose a component you get “that smell” Any help would be appreciated. I’m ready to buy the stator, rotor and PCB
#2 Posted : Thursday, February 16, 2012 1:13:48 PM(UTC)
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for LG WM2277HW Washer | AppliancePartsPros.com
MJE
#3 Posted : Sunday, June 17, 2012 12:07:17 PM(UTC)
MJE
Originally Posted by: smbokanyi Go to Quoted Post
Hello,
What did you discover was the solution for the problem? I bought a new stator assembly and that did NOT fix the issue. Was it your rotor assembly or the motor control unit?
thanks,
Mike
Replaced heating element assembly drum won't spin (Dryer Repair)
by ericrihm 2/28/2018 3:57:07 PM(UTC)
Maytag Bravos agitator works, but drum won't spin (Washer Repair)
by mcl143 8/23/2017 4:54:09 AM(UTC)
drum won't spin, agitator does (Washer Repair)
by wilcomj64 10/19/2015 7:39:20 PM(UTC)
Banging ... drum won't spin ... (Washer Repair)
by Hmmmm 2/8/2014 2:29:06 PM(UTC)
Drum won't spin but twitches trying to start (Washer Repair)
by itsnewtoyou 12/27/2013 11:47:10 AM(UTC)
Whirlpool Dryer drum won't spin (Dryer Repair)
by khangnguyen1 6/14/2012 5:40:31 PM(UTC)
Drum won't spin (Washer Repair)
by Tharyon 5/25/2011 9:28:05 AM(UTC)
Agitator makes a wierd sound and drum won't spin during wash cycles (Washer Repair)
by meanmommy 4/17/2011 9:49:19 PM(UTC)
dryer drum won't spin but all else is working (Dryer Repair)
by Burnhasl 12/29/2010 2:33:36 PM(UTC)
Agitator and drum won't spin (Washer Repair)
by wolfpackred2 10/12/2010 6:37:20 AM(UTC)
Agitator and Drum Won't Spin (Washer Repair)
by saquish 8/25/2010 10:32:53 AM(UTC)
Whirlpool dryer drum won't spin, but motor does (Dryer Repair)
by JeffWolfe 12/12/2009 8:54:52 PM(UTC)
Front Loader drum won't spin/agitate (Washer Repair)
by mfidds 7/25/2009 5:14:36 AM(UTC)
Drum won't spin (Dryer Repair)
by ALLAN1697 1/30/2009 9:14:43 AM(UTC)
