My Amana Model NAV6800AWW
, Serial Number 10211818CX decided to start leaking water. I have also noticed it has been sounding like a freight train during the spin cycle. The water seems to be only a mild puddle, but is definitely worse with a larger load. Otherwise, it seems to be doing alright. I investigated to ensure the water pump wasn't the source of the water. I verified that water was leaking down from around the top shaft of the transmission, around the tub bearing. From this, I believe I identified the kit I need: Part number: AP4261193
Is this correct? What I need now, though, is some mildly detailed instructions on installing the kit. Does the kit come with instructions, and if not where can I find them?
:)best info found at scibd.com and type in amana top loadwasher service manual and at american a/c & appliance washer repair then go to speed queen washer diagnostic chart and at point & click appliance repair under amana repair manuals:)
