rhcronin
#1 Posted : Thursday, July 23, 2009 10:59:30 AM(UTC)
rhcronin
I need a repair manual for a Maytag model A107 washing machine.
sidfink43
#2 Posted : Friday, July 24, 2009 9:32:41 AM(UTC)
sidfink43
I don't know of a repair manual for that model being availabe, because of age, but if you will tell us what your problem is and what you think you need to do we might (or might not, never can tell with us) be able to help.
rhcronin
#3 Posted : Wednesday, July 29, 2009 10:50:02 AM(UTC)
rhcronin
Of course I realize that a new repair manual might not be available from Maytag. (I tried that, and it isn't.) But surely some repairman somewhere must have one that could be photocopied. Anyway, for starters, how do you remove the top cover of the machine, and how do you remove the agitator?
sidfink43
#4 Posted : Wednesday, July 29, 2009 12:46:23 PM(UTC)
sidfink43
There should be two screws that hold the front panel on. Remove them (or if there are not screws, release clips between the front and top at each end) and take off the front panel. You will then see two screws that hold the top on, unscrew them and the top will come up.
As far as the agitator is concerned, see if this site will helpl you.
http://www.applianceaid.com/generalwash.html#geo
rhcronin
#5 Posted : Friday, August 7, 2009 8:45:26 PM(UTC)
rhcronin
Agitator removal tips mention a screw on the side or a bolt in the center. My machine has neither. No screws on front panel. Not sure what you mean by clips to be released.
applianceman
#6 Posted : Saturday, August 8, 2009 7:49:09 AM(UTC)
applianceman
A ¼ inch setscrew on the side of the agitator holds on the agitator. It is on the side near the bottom. The front may be held on with clips under the bottom front corners. Slide a screwdriver between the front and clip then you should be able to pull the front forward at the bottom. Once you pull the bottom out a foot or so the top clips should release. This page may help Maytag Tub Seal Replacement it shows how to take this washer apart.
