I have a washer than won't agitate.
not much to go on but try this first check the lid switch to see if its good you should hear a click when pressing it if that checks good then make sure that the motor coupler is in good shape your problem should be in one of these areas assuming that the motor or gear case are not bad also check the agitator dogs. hope this helps somewhat
