Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   water in tub (http://forum.appliancepartspros.com/washer-repair/41617-water-tub.html)
Aircraft 07-22-2009 06:33 PM
water in tub
Hello All,
Just wondering what else causes water to pool in the tub, but not everyday. I ran the machine thought one cycle and all worked well. Some times it take couple of hour or not at all. I am leaning to the fill valve inlet as the problem.
Gene 07-23-2009 01:48 PM
Most likely the problem is a bad water inlet valve.
- The water inlet valve Part number: AP3128776
Aircraft 08-08-2009 03:55 PM
Thanks for the reply Gene. I will change out the valve soon. We had water standing in it yesterday, first time sence the first post.
Dan
Gene 08-09-2009 09:20 PM
You are welcome Dan. Keep us posted.
