| » Frigidaire Affinity Washer Water Valve Harness Locking Plugs |
Model Number: LTF7000EG0 Brand: Frigidaire Age: 1 - 5 years
I ordered the replacement part for the water valve/Dispenser/NTC/Short Tube. There are three locking plugs in the water valve harness that connect to part I need to replace.
I've found the repair manual online, and it simply notes that these are locking plugs. I can see that there is a small ridge that is part of the locking mechanism, but even after lifting the plug away from that ridge, these three plugs do not want to come off. I'm hesitant to apply too much force trying to remove them. Does anyone know if there is a "trick" to disconnecting the locking plugs from the part so that I can replace the part? Ads By Google Related Models |
Check if there is another locking tab on the bottom of the plug. If not then just lift up the locking tab and pull the plug out.
Here are the breakdown diagrams and Replacement parts for FRG LTF7000EG0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
[quote=sadsack;113681]There are no screws in the back to take off. So how do i get it out?
You can find the instructions in the Service manual (this link would not last long - copy it to your comp).
Here are the breakdown diagrams and Replacement parts for FRG FLEB8200DS0 | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Frigidaire Affinity Paused | craftkween | Washer Repair | 2 | 10-21-2011 10:04 AM |
| water valve relay wiring harness | lc777@earthlink.net | Refrigerator & Freezer Repair | 0 | 01-09-2010 11:31 AM |
| Frigidaire Affinity Drier | billscov | Dryer Repair | 1 | 05-18-2009 01:19 PM |
| Frigidaire affinity | mrsakman | Dishwasher Repair | 1 | 10-23-2008 07:43 PM |
| Frigidaire affinity E41 error, washer not spinning | obstumps | Washer Repair | 0 | 05-16-2008 10:48 AM |
