| » Splashing over water on small load with bid speed |
Model Number: LTE6234DQ1 Brand: Whirlpool Age: More than 10 years
I do have problem with waser.It is running very high speed agitator on only on small load that cause of splashing water over.I thought it is timer or transmition but it is not. Help.Thanks.
If you are running a small load you should use the low water level selection.
If you are doing that, and you are still getting splashing water it may be that your problem is in the water level system because it is letting in too much water on the low level selection. Observe the water level under different selections to see if low level is working. If it is not, First, open the washer section and make sure the clear plastic tube running from the water level switch to the tub is clear and free of debris. You can disconnect it at the water level switch end and blow through it. The reattach it and see if the problem is fixed. Second, If that does not do it, and the water level is too high you will need to replace the water level switch itself. Good luck
__________________
| Display Modes | |
| Splashing over water on small load with high speed | portsmith | Washer Repair | 0 | 07-22-2009 11:59 AM |
| wont agitate if above small load | gidgit01 | Washer Repair | 1 | 05-02-2009 04:10 PM |
| Dryer works only with small load | Luis Rodriguez | Dryer Repair | 1 | 07-17-2008 06:09 PM |
| No fill on small load size | crosstalk | Washer Repair | 0 | 05-19-2008 07:26 AM |
| water splashing over front lip of tub | julieb | Dishwasher Repair | 4 | 12-04-2007 07:49 PM |
