| » Starts, but does not run thru cycle |
Model Number: FCCW3000FS4 Brand: Electrolux Age: 1 - 5 years
This machine got backed up with a plugged drain. Now it starts, will fill, but does not spin. It starts thru the timer cycle, but either takes very long or does not get thru it. When it got thru last time it pumped the loose water out, but the clothes were filled with water yet as it did not spin. Makes no noise, unless its in the pump cycle, and there is not enough water, then it makes a dry pump sound. Door seems to lock OK, and door lock light comes on.
My question- it seems I need an electronic control, there is a timer control near the coin changer, and a speed control on the lower rt rear corner. I would prefer to buy only one of these, but need get the washer going. I had a repair guy out, he just said to buy both or get a new washer. Because it's only 2 years old, I would prefer to repair it. Thank you. Bruce aka benjamin Ads By Google Related Models |
I would try changing out both of them, but if you buy from this site and you ultimately don't need the part you can return it. See the returns policy for details.
Inside the lower service panel should be some tech notes that will enable you to do some testing.
__________________
| Display Modes | |
| Agitator starts at very begining of each cycle | deputydan | Washer Repair | 1 | 04-13-2011 07:56 AM |
| Spin cycle starts only after On/Off OR Lid lift | Yvonn | Washer Repair | 2 | 03-08-2010 04:18 PM |
| Unit repeats cycle or starts by itself | alexc | Dishwasher Repair | 7 | 01-15-2009 08:19 PM |
| washer starts clicking when going to different cycle | hotdeal1957 | Washer Repair | 2 | 03-20-2008 11:45 PM |
| spin cycle starts slows starts | grhodes | Washer Repair | 0 | 12-18-2007 02:50 AM |
