Discuss
Error code SUD and F35
 in
Washer Repair
Hi ! my14 months old washer display SUD as soon as the water circle start and it blinks for about
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Error code SUD and F35
  #1 (permalink)
Old 07-21-2009, 05:18 PM
Junior Member
Tran58 is on a distinguished road
Default Error code SUD and F35
Brand: Kenmore   Age: 1 - 5 years
Hi ! my14 months old washer display SUD as soon as the water circle start and it blinks for about 3 or 4 min. .Then it shows F15.
Please help.Thank very much.
Ads By Google
  #2 (permalink)
Old 07-23-2009, 02:30 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If your machine is a front loader, you can take off the bottom front panel and you should find tech notes for trouble shooting.
If you need more info please post the full model number and what, if anything you learned from the troubleshooting.
__________________
  #3 (permalink)
Old 07-23-2009, 04:09 PM
Junior Member
Default Kenmore Elite He5t model #110.47791700
I did remove the lower panel and I don't see any tech note .I also clean the water pump.
Again it is the Kenmore Elite He5t washer, model# 110.47791700
  #4 (permalink)
Old 07-23-2009, 06:23 PM
Senior Expert
APP Volunteer
Default
Ok, take off the top and see if the tech notes are in there. They really should be inside the lower panel though.
Can you tell us exactly what happens and when. Your first post stated it happend in "water circle". Do you mean wash cycle, or exactly when.
Also, are you able to power down the machine, let it rest and then start it up again, with the same thing happening?
The F15 error is your motor control unit, but that is an expensive part so lets see if we can learn anything more
__________________
  #5 (permalink)
Old 07-25-2009, 04:51 PM
Junior Member
Default Problem with SUD + F35 error code
OK !!! This is what I foud.
If you have a bad pressure switch this SUD and F35 will show up. It will cost you $99 for the part .Plus what ever the technictian charge.
The real problem is ,Almost every Kenmore(made by Whirpool) and whirpool washer has this problem.So I wonder the manufacture did any thing with this or it's just anotherway for them to make money.Because $99 + Service charge is not cheap.
  #6 (permalink)
Old 07-25-2009, 05:49 PM
Senior Expert
APP Volunteer
Default
Well, sorry this happened but what you are experiencing is what those of us who work on these things know. The front loaders ( all brands) are great machines when they work, but they are prone to breakdown, are expensive to diagnose and repair and represent technology that really has not been perfected.
If it is any consolation this is one of the less expensive repairs that you could have.
Good luck in the future with your machine
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
error code 40 kimbrecht69@hotmail.com Oven Repair (including Ranges and Cooktops) 1 11-03-2010 12:07 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
GE error code F3 Mako Oven Repair (including Ranges and Cooktops) 20 04-10-2008 09:03 PM
F33 error code daphil Washer Repair 1 03-27-2008 06:02 PM
error code f13 banks Oven Repair (including Ranges and Cooktops) 1 01-17-2008 11:11 AM
