HI i hope to find some help here my washer is a front loader 31/2 years old the problem is it is doing the cycle but pauses at the rinse cycle a few times what could the problem be i have had the tech clean the water filter
Well the tech should have also diagnosed the problem.
Intermittent problems are difficult to diagnose. The inverter on this model is the likely suspect but you will have to replace it to see if that is indeed the problem.
