Discuss
Roper washing machine shakes during spin cycle...
 in
Washer Repair
When the washing machine is in the spin cycle it shakes/viborates very badly. It is not the type of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washing machine shakes during spin cycle...
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
LinkBack (2) Thread Tools Search this Thread Display Modes
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-06-2008, 05:12 PM
zoe1594 zoe1594 is offline
Junior Member
zoe1594 is on a distinguished road
Default Roper washing machine shakes during spin cycle...
Brand: Roper   Age: 1 - 5 years
When the washing machine is in the spin cycle it shakes/viborates very badly. It is not the type of shake that it would do if it is off balance, but it is bad. We had thought that it was the floor the washer was sitting on since it only started after we moved to our current home. We added more support to the floor joists and it did nothing for our problem. What else should we check? I have checked the problem with the washer empty and it did the same thing. Please help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-06-2008, 05:44 PM
fyxer fyxer is offline
Junior Member
fyxer is on a distinguished road
Default machine shakes during spin cycle
This sound like your machine is unbalanced,adding padding to the floor joists does not automatically balance the machine,even checking the machine with a level doesen't always mean the machine is level--the best way to check a machine is to stand in front of the machine,with both hands try to rock the machine from front to back and from side to side,if there is no movement from the machine it is level--but for instance if the machine tilts back and forth from left front to right rear when you push on the top with both hands--this mean that only three legs are touching the floor--you will need to adjust the left front leg so all four legs are firmly touching the floor.
  #3 (permalink)
Old 01-07-2008, 04:21 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would pull off the outer cabinet and check the tub support springs, sometimes they rust off. If ok, I would check the skate board under the tub, check left and right sides for symmetry, if off, just move it up and down to position it properly.
__________________
  #4 (permalink)
Old 06-09-2008, 12:22 PM
Michael5000 Michael5000 is offline
Junior Member
Michael5000 is on a distinguished road
Default Shaking Roper
I just had the same problem with my Roper Washing Machine. My contractor installed it but didn't remove the packaging material which stabilizes the drum during shipping. Roper Customer Service said that this could cause sever shaking. My contractor didn't read the instructions. I tilted the machine forward and saw a yellow plastic tab underneath which had been cut. I grabbed it and tugged and out came the foor-long pin that hold the drum in place during shipping. Now there is only a slight tolerable shake. Make sure to unplug your machine first. Good luck.
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/4144-roper-washing-machine-shakes-during-spin-cycle.html
Posted By For Type Date
Digg - Roper washing machine shakes during spin cycle... This thread Refback 01-07-2008 06:16 PM
Digg / All News, Videos, & Images / Upcoming This thread Refback 01-06-2008 05:50 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Washing Machine mjt240 Washer Repair 1 11-26-2007 06:50 PM
roper washing machine leaking red oil bandksdad Washer Repair 1 11-22-2007 10:39 PM
Washing Machnie shaking uncontrolable on spin cycle Sherman Washer Repair 0 10-28-2007 03:11 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
Washing Machine runs through cycle in two minutes scully27926 Washer Repair 1 08-07-2007 08:28 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
