Maytag clothes washer, new pump and belt replaced, clothes wet after spin, more quest
Model Number: MAV6000AWW Brand: Maytag Age: More than 10 years
Maytag washer Model Number MAV6000AWW
Problem: Filling and agitation are fine. After rinsing, most water is drained out, but clothes are very wet after spin cycle. After replacing new pump and new belt, the problem was the same.
I bought the Serve Manual, and followed every item under Clothes Wet After Spin. After excluding the possibilities of unbalanced load, slipping belt, pump obstruction, drain hose restriction, and drain plumbing restriction, I checked the reference marks on drive pulley and cams. I tried every possibility, adding one, two, and three thrust washers, starting at marks of 4, 6, and 9, but did not see any improvement. Then I tried to check for partial engagement of brake assembly, because I do feel the spin speed is not as fast as before. But I do not know how to do torque testing. The Service Manual said, Place a 1/2 inch socket and torque wrench on the agitator retaining bolt. Depress the safety spin switch to allow the washer to operate in the spin cycle, then while reading the torque allow the wrench to turn slowly (6 RPM) through a complete 360 degree cycle, the reading should be between 18 and 25 inch pounds. (1) I could not find the agitator retaining bolt. There is an agitator retaining screw under the plastic agitator base. I may use a wrench to tighten or loose it, but no way to turn it a 360 degree cycle. (2) I could not find the safety spin switch to depress it to allow the washer to operate in the spin cycle. Is it on the control panel? If I turn the timer knob to spin location, when the lid is open, the agitator will not spin, and the agitator retaining screw but I cannot turn it with wrench; If the lid is close, the agitator will spin, but the screw is not accessible. What should I do? Pleas advise me. Thank you very much. Adam
Ads By Google
Related ModelsMaytag MAV6000AWW Washer, Atlantis Maytag MAV6057AWQ Washer, Atlantis Maytag MAV6057AWW Washer, Atlantis Maytag MAV6200AWQ Washer, Atlantis Maytag MAV6200AWW Washer, Atlantis Maytag MAV6250AWQ Washer, Atlantis Maytag MAV6250AWW Washer, Atlantis Maytag MAV6257AWQ Washer, Atlantis Maytag MAV6257AWW Washer, Atlantis Maytag MAV6260AWW Washer, Atlantis International MAV6300AGW Washer - Top Loading Maytag MAV6300AWQ Washer, Atlantis Maytag MAV6300AWW Washer, Atlantis International MAV6300BGW Washer - Top Loading International MAV6300CGW Washer - Top Loading Maytag MAV6357AWW Washer, Atlantis Maytag MAV6358AWW Washer, Atlantis Maytag MAV6451AGW Washer, Atlantis Maytag MAV6451AWQ Washer, Atlantis Maytag MAV6451AWW Washer, Atlantis Maytag MAV6457AWW Washer, Atlantis Maytag MAV6458AWW Washer, Atlantis Maytag MAV6548AWQ Washer, Atlantis Maytag MAV6548AWW Washer, Atlantis Maytag MAV6601AWQ Washer, Atlantis Maytag MAV6601AWW Washer, Atlantis Maytag MAV6650AWW Washer, Atlantis Maytag MAV7000AWQ Washer, Atlantis Maytag MAV7000AWW Washer, Atlantis Maytag MAV7057AWQ Washer, Atlantis Maytag MAV7057AWW Washer, Atlantis Maytag MAV7200AWQ Washer, Atlantis Maytag MAV7200AWW Washer, Atlantis Maytag MAV7257AWQ Washer, Atlantis Maytag MAV7257AWW Washer, Atlantis Maytag MAV7258AWQ Washer, Atlantis Maytag MAV7258AWW Washer, Atlantis Maytag MAV7260AWW Washer, Atlantis Maytag MAV7260BWW Washer, Atlantis Maytag MAV7357AWQ Washer, Atlantis Maytag MAV7357AWW Washer, Atlantis Maytag MAV7358AWQ Washer, Atlantis Maytag MAV7358AWW Washer, Atlantis Maytag MAV7450AWQ Washer, Atlantis Maytag MAV7450AWW Washer, Atlantis Maytag MAV7501EWW Washer, Atlantis Maytag MAV7504EWW Washer, Atlantis Maytag MAV7550AWQ Washer, Atlantis Maytag MAV7550AWW Washer, Atlantis Maytag MAV7551AWQ Washer, Atlantis Maytag MAV7551AWW Washer, Atlantis Maytag MAV7557EWQ Washer, Atlantis Maytag MAV7557EWW Washer, Atlantis Maytag MAV7580EWQ Washer, Atlantis Maytag MAV7580EWW Washer, Atlantis International MAV7600ACQ Washer - Top Loading International MAV7600AGW Washer - Top Loading Maytag MAV7600AWQ Washer, Atlantis Maytag MAV7600AWW Washer, Atlantis International MAV7600BGW Washer - Top Loading International MAV7600CGW Washer - Top Loading Maytag MAV7650AWQ Washer, Atlantis Maytag MAV7650AWW Washer, Atlantis Maytag MAV7657EWQ Washer, Atlantis Maytag MAV7657EWW Washer, Atlantis Maytag MAV7700AWQ Washer, Atlantis Maytag MAV7700AWW Washer, Atlantis International MAV7750AGW Washer - Top Loading International MAV7750BGW Washer - Top Loading International MAV7750CGW Washer - Top Loading Maytag MAV7757AWQ Washer, Atlantis Maytag MAV7757AWW Washer, Atlantis Maytag MAV8000AWQ Washer, Atlantis Maytag MAV8000AWW Washer, Atlantis Maytag MAV8057AWQ Washer, Atlantis Maytag MAV8057AWW Washer, Atlantis Maytag MAV8260AWQ Washer, Atlantis Maytag MAV8260AWW Washer, Atlantis Maytag MAV8500AWA Washer, Atlantis Maytag MAV8500AWQ Washer, Atlantis Maytag MAV8500AWW Washer, Atlantis Maytag MAV8551AWQ Washer, Atlantis Maytag MAV8551AWW Washer, Atlantis Maytag MAV8557AWQ Washer, Atlantis Maytag MAV8557AWW Washer, Atlantis Maytag MAV8600AWQ Washer, Atlantis Maytag MAV8600AWW Washer, Atlantis Maytag MAV8601AWQ Washer, Atlantis Maytag MAV8601AWW Washer, Atlantis Maytag MAV8757AWQ Washer, Atlantis Maytag MAV8757AWW Washer, Atlantis Maytag MAV9501EWQ Washer, Atlantis Maytag MAV9501EWW Washer, Atlantis Maytag MAV9504EWQ Washer, Atlantis Maytag MAV9504EWW Washer, Atlantis Maytag MAV9557EWQ Washer, Atlantis Maytag MAV9557EWW Washer, Atlantis Maytag MAV9600EWQ Washer, Atlantis Maytag MAV9600EWW Washer, Atlantis Maytag MAV9657EWQ Washer, Atlantis Maytag MAV9657EWW Washer, Atlantis Maytag MAV9750AGW Washer, Atlantis Maytag MAV9750AWQ Washer, Atlantis Maytag MAV9750AWW Washer, Atlantis Maytag MAVT236AWW Washer - Top Loading Maytag MAVT346AWW Washer - Top Loading Maytag MAVT446AWW Washer - Top Loading Maytag MAVT546EWW Washer - Top Loading Maytag MAVT634AWW Washer, Atlantis Maytag MAVT734EWW Washer, Atlantis Maytag MAVT754EWW Washer, Atlantis Maytag MAVT834AWQ Washer, Atlantis Maytag MAVT834AWW Washer, Atlantis Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot International MB1927PEHB Ref - Maytag Int'l Bot Mount International MB1927PEHW Ref - Maytag Int'l Bot Mount International MB2216PUAW Ref - Bottom Mounts International MB2227PEHB Ref - Maytag Int'l Bot Mount International MB2227PEHW Ref - Maytag Int'l Bot Mount Thermador MB245
