I have to close the door several times harder than normal in order for the door to lock. It sounds as if it's about to lock, but then I get a code PAV. Could this be the door/lock switch?
It sounds like the door lock is broken, but check the wiring and connections to make sure they were not damaged. If the machine is less than one year old it should be under factory warranty.
