Discuss
Roper washer will not drain
 in
Washer Repair
Was using my washer this am and did a few loads. on the last spin cycle of the last load
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer will not drain
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-06-2008, 11:04 AM
maximum destruction maximum destruction is offline
Junior Member
maximum destruction is on a distinguished road
Default Roper washer will not drain
Model Number: rax4232kq1   Brand: Roper   Age: 1 - 5 years
Was using my washer this am and did a few loads. on the last spin cycle of the last load most of the water drained into my laundy tub, but it has stopped draining and ther is a different sound to the unit not overly load just a different sound, Any info help greatly appreciated.
Maximum Destruction
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 09:20 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What kind of noise it makes?
Does the motor run?
Does it agitate and/or spin?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-07-2008, 02:46 PM
Junior Member
Default
its kind of a louder hum, it agitates and spins. With the diagrams from the other post you sent, I am going to haul the box off and check the pump and the in/out lines for foreign material.
Maximum
  #4 (permalink)
Old 01-07-2008, 03:35 PM
Junior Member
Smile fixed
Thanks for the info Gene. I hauled the housing off and checked the incoming and out going lines from the pump , and sure enough there was a toddlers blue Old Navy sock stuck there. Checked a couple cycles and seems to be draining fine. We will put her to the test shortly.
Thank you ,
Maximum Destruction ( my little boy came up with this name)
  #5 (permalink)
Old 01-07-2008, 03:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper washer will not spin, agitate, pump litexp2 Washer Repair 16 09-26-2008 12:53 PM
roper washer question whitehanes34 Washer Repair 2 12-02-2007 12:03 PM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 01:41 PM
Roper Washer Noise/Alarm during wash cycle neworleans70 Washer Repair 2 11-25-2007 07:14 AM
Roper washer will not spin rodtamara Washer Repair 0 11-12-2007 03:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
