Washer's hot water fills up very slowly. Please advise on what to do.
The first thing to do is to disconnect the hot water line and see if there is some debris in the screens in the valves. Also put the hot water hose into the tub and see if the water coming in is at full pressure.
If those check out the hot water valve may not be opening all the way and replacing the valve assembly should fix things.
Thank you I will try that.
