Washer started a grinding noise during the wash cycle. Now it will only make the noise and then flash an error message. What happened?
Look inside the lower service panel and you should find some tech notes that will tell you what the error code means and how to do some testing to check out the parts
Also, take off the back and check the support struts and structure.
Were you able to fix this issue? I am having a similar problem what was the cause?
