Discuss
Only operates at slow speed
 in
Washer Repair
No matter which cycle you set the machine to run, it only operates in delicate (slow) spin and agitate. Also
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Only operates at slow speed
  #1 (permalink)
Old 07-18-2009, 03:43 PM
Junior Member
Tanglewood is on a distinguished road
Default Only operates at slow speed
Model Number: LW8253W   Brand: Amana   Age: More than 10 years
Also slight water leak sometimes in right front area. Today we think it might have emitted grease into the tub during the spin. Not sure, as we could not duplicate on next wash. (Could have been in the clothes)
Related Models
Amana LW8253W WASHER-TOP LOADING
Amana LW8263W2 WASHER-TOP LOADING
Amana LW8303L2 WASHER-TOP LOADING
Amana LW8303W2 WASHER-TOP LOADING
Amana LW8312L2 WASHER-TOP LOADING
Amana LW8312W2 WASHER-TOP LOADING
Amana LW8363L2 WASHER-TOP LOADING
Amana LW8363W2 WASHER-TOP LOADING
Amana LW8403W WASHER-TOP LOADING
Amana LW8413L2 WASHER-TOP LOADING
Amana LW8413W2 WASHER-TOP LOADING
Amana LW8413W2B WASHER-TOP LOADING
Amana LW8463L2 WASHER-TOP LOADING
Amana LW8463W2 WASHER-TOP LOADING
Amana LW9003 WASHER-TOP LOADING
Amana LW9103 WASHER-TOP LOADING
Amana LW9103W WASHER-TOP LOADING
Amana LW9203L2 WASHER-TOP LOADING
Amana LW9203W WASHER-TOP LOADING
Amana LW9203W2 WASHER-TOP LOADING
Amana LWA05AW WASHER-TOP LOADING
Amana LWA10AW WASHER-TOP LOADING
Amana LWA18AW WASHER-TOP LOADING
Amana LWA20AW WASHER-TOP LOADING
Amana LWA30AL WASHER-TOP LOADING
Amana LWA30AW WASHER-TOP LOADING
Amana LWA30BL WASHER-TOP LOADING
Amana LWA30BW WASHER-TOP LOADING
Amana LWA40AL WASHER-TOP LOADING
Amana LWA40AL2 WASHER-TOP LOADING
Amana LWA40AW WASHER-TOP LOADING
Amana LWA40AW2 WASHER-TOP LOADING
Amana LWA50AL WASHER-TOP LOADING
Amana LWA50AW WASHER-TOP LOADING
Amana LWA60AL WASHER-TOP LOADING
Amana LWA60AW WASHER-TOP LOADING
Amana LWA65AL WASHER-TOP LOADING
Amana LWA65AW WASHER-TOP LOADING
Amana LWA80AL WASHER-TOP LOADING
Amana LWA80AW WASHER-TOP LOADING
Amana LWA90AL WASHER-TOP LOADING
Amana LWA90AW WASHER-TOP LOADING
Amana LWC05AW WASHER-TOP LOADING
Amana LWC07AW WASHER-TOP LOADING
Amana LWC18AW WASHER-TOP LOADING
Amana LWC30AW WASHER-TOP LOADING
Amana LWC40AW WASHER-TOP LOADING
Amana LWC50AW WASHER-TOP LOADING
Amana LWC75AW WASHER-TOP LOADING
Amana LWC80AW WASHER-TOP LOADING
Amana LWC90AW WASHER-TOP LOADING
Amana LWD250 WASHER-TOP LOADING
Amana LWD27AW WASHER-TOP LOADING
Amana LWD27BW WASHER-TOP LOADING
 LWD3081ST Electric Range
Amana LWD352 WASHER-TOP LOADING
Amana LWD352L WASHER-TOP LOADING
Amana LWD352W WASHER-TOP LOADING
Amana LWD353 WASHER-TOP LOADING
Amana LWD353L WASHER-TOP LOADING
Amana LWD353W WASHER-TOP LOADING
Amana LWD35AW WASHER-TOP LOADING
Amana LWD37AW WASHER-TOP LOADING
Amana LWD40AW WASHER-TOP LOADING
Amana LWD450 WASHER-TOP LOADING
Amana LWD453 WASHER-TOP LOADING
Amana LWD553 WASHER-TOP LOADING
Amana LWD553L WASHER-TOP LOADING
Amana LWD553W WASHER-TOP LOADING
Amana LWD650 WASHER-TOP LOADING
Amana LWD662 WASHER-TOP LOADING
Amana LWD67AL WASHER-TOP LOADING
Amana LWD67AW WASHER-TOP LOADING
Amana LWD70AL WASHER-TOP LOADING
Amana LWD70AW WASHER-TOP LOADING
Amana LWD75AW WASHER-TOP LOADING
Amana LWD773 WASHER-TOP LOADING
Amana LWD773L WASHER-TOP LOADING
  #2 (permalink)
Old 07-20-2009, 05:53 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Tanglewood
If you will take off the front of your machine (release two clips at the outer part of the gap between the front panel and top) you can observe the machine running and determine where your leak originates.
With respect to your spin issue, it's hard to tell but the timer would be the first suspect. If you continue to get grease in your clothes it is probably coming from the transmission and a new machine will be in order.
Hope this helps, good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer spin speed too slow arkie102 Washer Repair 10 12-24-2012 01:07 AM
slow spin out speed Carl Ambrose Washer Repair 1 11-16-2009 06:53 AM
Slow drum speed on spin cycle Pritchard Washer Repair 3 04-13-2009 08:46 PM
Agitator Move Slow And No High Speed Spin And Clothes Are Soaking Wet JEFF1969 Washer Repair 0 01-31-2009 08:40 AM
Gentle cycle/slow spin speed problem WFH Washer Repair 1 01-19-2008 08:17 PM
