| » Washer Drum out of balance |
Model Number: PAV2300AWW Brand: Maytag Age: 5 - 10 years
Like a similar post earlier i also have a Maytag washer with a wobble in the drum during spin cycle. the model number is PAV2300AWW. even a very small and light load of cloths causes the drum to wobble during the rinse and spin cycle enough to cause the machine to move around the floor. Any thoughts?
Related Models |
It's likely one spring has sprung. Look at the base assembly drawing. Spring 18 is likely the culprit. The hooked end may have rusted off, or the hole in the sheet metal where the spring connects has rusted through. If this is the case, drill a new hole close by. Buy the new spring if necessary, too.
Good luck! |
| Display Modes | |
| kenmore front load washer drum off balance and bangs in one location | kemily | Washer Repair | 3 | 10-23-2009 06:56 AM |
| washer balance | randylanham | Washer Repair | 0 | 11-25-2007 11:58 AM |
| Chriping noise when washer drum changes direction | Rikam | Washer Repair | 0 | 11-19-2007 01:59 PM |
| washer off balance what to repalce/fix | washerwoes | Washer Repair | 3 | 11-01-2007 10:19 PM |
| Washer out-of-balance during spin | morrey15 | Washer Repair | 0 | 10-02-2007 11:39 PM |
