blankenshiphamilton
#1 Posted : Saturday, July 18, 2009 12:39:35 PM(UTC)
blankenshiphamilton
When my maytag neptune goes into spin,it is extremely loud. I discovered that this was caused by bad bearings in the back of the drum. How can these be changed out?
NeptuneHelp
#2 Posted : Sunday, July 19, 2009 8:30:19 AM(UTC)
NeptuneHelp
See NEPTUNE BEARING for the replacement bearings and seal kit. You can also rent a slick tool kit to help you change your bearings. The tool rental also includes use of a DVD that shows Neptune disassemble, bearing swap and seal kit installation.
While I have your attention… Have you changed your door latch wax motor yet? Please see NEPTUNE HELP for details to prevent a control board failure. Note: If you own an earlier MAH3000 Neptune then you will have (2) more wax motors in the soap dispenser that should be replaced as well. I offer a (2) pack of wax motors just for the earlier MAH3000’s.
Check out the new funny Neptune Help song at NEPTUNE HELP SONG which explains the faulty door latch wax motor issue.
