Discuss
nothing works
 in
Washer Repair
washer stopped working when i unplugged it to move to new house. power supply is good, push/pull switch works and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » nothing works
  #1 (permalink)
Old 02-01-2012, 09:18 AM
Junior Member
900hpv6tbird is on a distinguished road
Default nothing works
Model Number: MAV8057AWW   Brand: Maytag   Age: 5 - 10 years
washer stopped working when i unplugged it to move to new house. power supply is good, push/pull switch works and lid switch is good, i pulled the control panel apart and check for some power and grounds based of of the supplied diagram and believe it is the water/temp control switch. my wife wants me to be sure by asking a expert, so here i am....lol any help would be appreciated!
Ads By Google
Related Models
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
  #2 (permalink)
Old 02-02-2012, 06:15 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It could be be the temp selection switch, but first move the timer to spin and see if it spins. That will show that power is getting to the timer and that the time is maybe ok. If it will spin, fill it with a hose and see if it will go into agitation. If it will then check out both the temp switch and the water level switches.
You may have to change them out, but if you buy from this site and the part is not needed or does not fix the problem you can return it, see the returns policy for details and conditions.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer works, but the timer does not work in permanent press, but works in timed dry. blevinsrl Dryer Repair 5 05-20-2011 01:56 PM
Range works/ stove ignitor works doesnt have gas brapallo Oven Repair (including Ranges and Cooktops) 1 04-19-2011 08:57 AM
Wall oven bake element not working! Broil works, clock works. ajachyra Oven Repair (including Ranges and Cooktops) 1 12-02-2009 06:30 AM
Oven will not turn on, broiler works, stove top works caewart Oven Repair (including Ranges and Cooktops) 1 06-20-2009 05:25 AM
Dryer Works, Doesnt Work, Works Again timber284 Dryer Repair 0 08-01-2008 09:56 AM
