Discuss
Kenmore Washer Issues
 in
Washer Repair
The Machine Will Fill, Wash, And Empty. At The Rinse Cycle Position Of The Selector, It Just Stops And Will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer Issues
  #1 (permalink)
Old 02-01-2012, 07:23 AM
Junior Member
MIKEFINK is on a distinguished road
Default Kenmore Washer Issues
Model Number: 11028322700   Brand: Kenmore   Age: 5 - 10 years
The Machine Will Fill, Wash, And Empty. At The Rinse Cycle Position Of The Selector, It Just Stops And Will Not Rinse Or Advance. If You Manually Advance It To Spin It Will Spin Out And Finish The Load?
Ads By Google
Related Models
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Sears 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Sears 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Sears 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Sears 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Sears 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362821 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363076 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364760 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365013 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365196 GEARCASE AND SUPERSTRUCTURE
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365948 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366559 GEARCASE AND SUPERSTRUCTURE
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110386842 WATER SAVER
Kenmore 110387948 BRAKE AND DRIVE TUBE
Kenmore 110388951 BRAKE AND DRIVE TUBE
Kenmore 110388952 BRAKE AND DRIVE TUBE
Kenmore 110389246 GEARCASE PARTS
Kenmore 110395055 GEARCASE AND SUPERSTRUCTURE
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
  #2 (permalink)
Old 02-02-2012, 06:11 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Ssince it works mechanically it would seem that the timer is the issue. Try changing it out and see if that fixes the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Issues MIKEFINK Washer Repair 1 01-31-2012 02:51 AM
Kenmore Model 80 washer coupler/tranny issues Ken More Washer Repair 1 01-08-2012 05:21 PM
Old Kenmore Agitation Issues krich Washer Repair 10 12-24-2011 01:40 AM
Kenmore washer timer issues? Help please. ffspiel Washer Repair 2 06-06-2010 05:10 PM
Kenmore Washer issues- starts by itself sainadh Washer Repair 4 09-01-2009 05:09 AM
