Discuss
GE washer makes clicking sound
 in
Washer Repair
Hello, The washer makes a clicking sound when agitating or spinning. Sometimes, the agitating and spinning stops, and sometimes it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer makes clicking sound
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-05-2008, 09:48 AM
Kyle Kyle is offline
Junior Member
Kyle is on a distinguished road
Default GE washer makes clicking sound
Model Number: WPSE5290A0WW   Brand: GE   Age: 5 - 10 years
Hello,
The washer makes a clicking sound when agitating or spinning. Sometimes, the agitating and spinning stops, and sometimes it does not.
While it is making the clicking sound, house lights dim.
Since it does agitate, I feel the agitator coupler is good; also, the agitator does not move by hand. And since it does spin, I feel the belt is okay.
I think the problem is the motor. I've seen places online that mention a "fix kit" for this clicking problem. Do you know if one exists?
Or, do you think I just need a new motor? and clutch assembly also?
thanks for looking at this,
Kyle
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-06-2008, 08:25 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You have a bad centrifical switch in the motor that can't be replaced. You can try a non-residue spray on it, make sure it's dry before starting.
__________________
  #3 (permalink)
Old 01-06-2008, 12:15 PM
Junior Member
Default
If the non-residue spray does not fix the problem, then I need to install a new motor, is that right? Is a new motor install straightforward, just a matter of unclipping the wires and unbolting?
  #4 (permalink)
Old 01-06-2008, 04:18 PM
Senior Expert
APP Volunteer
Default
Yes an easy job, just pull on the motor to put a bit of tension on the belt. I checked a motor and there is no way to activate the switch externally, so spraying may not have much effect.
__________________
  #5 (permalink)
Old 01-12-2008, 04:53 PM
Junior Member
Default
I will get a new motor; how do I open the washer up to replace the motor?
  #6 (permalink)
Old 01-13-2008, 01:41 AM
Senior Expert
APP Volunteer
Default
Push a putty knife under the top where the clips are and pry the front panel forward. Remove the bottom motor nuts and remove motor. Install the new motor, pull forward to put tension on the belt and tighten the nuts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer not cooling/making clicking sound momof1 Refrigerator & Freezer Repair 3 12-12-2007 01:36 PM
agitator makes clicking noise GLS32060 Washer Repair 0 11-25-2007 09:52 AM
Dryer makes a loud pinging sound Krwool Dryer Repair 2 08-21-2007 01:59 AM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 08:00 PM
Freezer fan makes a rattleing sound Ben Tym Refrigerator & Freezer Repair 6 08-10-2007 02:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
