Washer goes through wash cycle but when it gets to the spin cycle the motor runs but the washer does not spin. I have to restart from the beginning and then it normally works fine....it happens once every 5 to 10 loads
Check out the clutch, this part here Part number: AP3094538
The video will show you how to get into the machine to work on it. This is a relatively easy repair but it will help immensely to have a helper.
