dallas_clement
#1 Posted : Sunday, January 29, 2012 6:16:12 PM(UTC)
dallas_clement
My washer recently started making squeaking and thunking noises while washing a load. Yesterday I noticed that at the end of a cycle, my towels were still sopping wet. I then turned the control to the drain/spin cycle to observe. I could hear it draining, but the drum did not spin fast like it normally does. It rotated very slowly. Any ideas what the problem could be?
sidfink43
#2 Posted : Tuesday, January 31, 2012 5:20:32 PM(UTC)
sidfink43
Clean out the pump and check for obstruction and blockage.
If that is okay, use the tech notes under the top to do some diagnostic testing.
rem870
#3 Posted : Monday, February 20, 2012 4:51:16 PM(UTC)
rem870
I am having the same problem different model but, a whirlpool frontload, where you able to fix the problem?
