Need help diagnosing washer, water will not stop flowing, so it wont go into agitate cycle, it will drain and spin if manually moved at dial, but wont agitate, help,thx
Could be a restriction plugging the air tube that goes to the water level pressure switch.
Thx, is that located in back part of washer
