I Said In My Last Post That The Motor Is Running And Still Not Spinning. An After Thought Is That Ht E Pump Is Running And Not The Motor. Where Would I Start To Look For Problems First?
I was able to fix my problem by taking the front access panel off and open the top of the boot that goes to the pump. In the boot is a coin trap, which had two quarters, four dimes, two pennies, a key and two bread bag plastic locking tabs(with lint stuck to the bread tabs). After removing said debris and reinstalling coin trap and boot the washer spun perfect. My initial problem was the dryer belt had burned off. After fixing that problem I noticed the problem with the washer. By putting two and two together I came up to the conclusion that the dryer belt burned off one that it is four years old and stretched. The other was with the heavy wet load from laundry still being wet that it overloaded the dryer. So everything is once again working fine. Thanks again for the reply, Marty Originally Posted by: Chris_Polk You may have a faulty connection with the motor and the pump, or the control board. Have you had anyone check the control board to the unit? Start there and keep us posted please.
