washer does not agitate
Model Number: A612S Brand: Maytag Age: More than 10 years
I have a Maytag washer model A612S that does not agitate. It will fill, spin and empty the water but does not agitate at all. I checked the belts, and although worn, they were still intact. With the water turned off, belts removed, and the washer set to a wash cycle, I am able to turn the main pulley by hand in both directions. If I fill the washer with water, and with the belts in place, the motor will turn the pump pulley and belt fine. The main drive belt does not turn the main pulley in the wash cycle it just sits and rubs against the motor pulley. The main drive pulley does engage in the spin cycle and pumps out the water. Any suggestions or past experience regarding this problem would be a big help.
Ads By Google
Related ModelsMaytag A612S Washer - Top Loading Maytag A612ST Washer - Top Loading Maytag A612T Washer - Top Loading Maytag A613 Washer - Top Loading Maytag A613T Washer - Top Loading Admiral A6257XRS Range - S/i Cont Clean Gas Jenn-Air A626 Misc / Accessory Jenn-Air A626B Misc / Accessory Jenn-Air A626W Misc / Accessory Jenn-Air A627B Misc / Accessory Jenn-Air A627W Misc / Accessory Admiral A6498VRV Range - S/c S/i Gas Admiral A6498XRS Range - S/c S/i Gas Admiral A64HN-4TKVW-R Range - S/c S/i Gas Admiral A6892XRS Range - S/c S/i Ele Admiral A6898VRV Range - S/c S/i Ele Admiral A6898XRB Range - S/c S/i Ele Admiral A68HK-6TXW-R Range - S/c S/i Ele Maytag A6910 Washer - Top Loading Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner Maytag A700 Washer - Top Loading Maytag A700S Washer - Top Loading Maytag A702 Washer - Top Loading Maytag A702S Washer - Top Loading Maytag A710 Washer - Top Loading Maytag A710S Washer - Top Loading Maytag A712 Washer - Top Loading Maytag A712T Washer - Top Loading Maytag A7300 Washer - Top Loading Maytag A7400 Washer - Top Loading Maytag A7500 Washer - Top Loading Maytag A7500S Washer - Top Loading Maytag A7500W Washer - Top Loading Maytag A7800 Washer - Top Loading Admiral A79E-5CXW Walloven - S/c Ele Admiral A79F-5EXW-R Walloven - S/c Ele Admiral A79FN-5EVW-R Walloven - S/c Ele Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner Maytag A806 Washer - Top Loading Maytag A806S Washer - Top Loading Maytag A810 Washer - Top Loading Maytag A8100 Washer - Top Loading Maytag A8120 Washer - Top Loading Maytag A8140 Washer - Top Loading Maytag A8200 Washer - Top Loading Maytag A8210 Washer - Top Loading Admiral A8210PA Surface Unit - Gas Admiral A8210PA-L Surface Unit - Gas Admiral A8210PT-L Surface Unit - Gas Admiral A8210PW Surface Unit - Gas Admiral A8210PW-L Surface Unit - Gas Admiral A8211PA Surface Unit - Gas Admiral A8211PS Surface Unit - Gas Admiral A8211PW Surface Unit - Gas Maytag A8240 Washer - Top Loading Admiral A8241RA Surface Unit - Gas Admiral A8241RA-L Surface Unit - Gas Admiral A8241RS Surface Unit - Gas Admiral A8241RT-L Surface Unit - Gas Admiral A8241RV Surface Unit - Gas Admiral A8241RW Surface Unit - Gas Admiral A8241RW-L Surface Unit - Gas Admiral A8261RB Surface Unit - Gas Admiral A8261RV Surface Unit - Gas Admiral A82LK-3K-R Surface Unit - Gas Admiral A82LN-3K-R Surface Unit - Gas Admiral A82LW-2K-R Surface Unit - Gas Admiral A82R1RV Surface Unit - Gas Admiral A8321PA Surface Unit - Gas Admiral A8321PS Surface Unit - Gas Admiral A8321PW Surface Unit - Gas Admiral A8321TA-L Surface Unit - Gas Admiral A8321TW-L Surface Unit - Gas Maytag A8340 Washer - Top Loading Maytag A8420 Washer - Top Loading Maytag A8440 Washer - Top Loading Maytag A8500 Washer - Top Loading Maytag A8520 Washer - Top Loading Maytag A8600 Washer - Top Loading Admiral A8610PA Surface Unit - Ele Admiral A8610PS Surface Unit - Ele Admiral A8610PV Surface Unit - Ele Maytag A8640 Washer - Top Loading Maytag A8650 Washer - Top Loading Admiral A8670PB Surface Unit - Ele Admiral A8670PV Surface Unit - Ele Admiral A86LW-1-R Surface Unit - Ele Maytag A8700 Washer - Top Loading Admiral A8720PA Surface Unit - Ele Admiral A8720PW Surface Unit - Ele Maytag A8740 Washer - Top Loading Maytag A8800 Washer - Top Loading Maytag A882 Washer - Top Loading Maytag A8820 Washer - Top Loading Maytag A882T Washer - Top Loading Maytag A883 Washer - Top Loading Maytag A883T Washer - Top Loading Maytag A884 Washer - Top Loading Maytag A8840 Washer - Top Loading Maytag A884T Washer - Top Loading Admiral A88FK-1 Surface Unit - Ele Admiral A88FK-2-R Surface Unit - Ele Admiral A88FK-6-R Surface Unit - Ele Admiral A88FN-2-R Surface Unit - Ele Admiral A88FN-2R Surface Unit - Ele Admiral A88LK-6-R Surface Unit - Ele Admiral A88LN-6-R Surface Unit - Ele Admiral A89L-4-R Surface Unit - Ele Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
