Discuss
Whirlpool Cabrio getting F50 F51 fault codes
 in
Washer Repair
My Whirlpool Cabrio is getting an F50 fault code when it attempts to spin. When I activate the auto diagnostic
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Cabrio getting F50 F51 fault codes
  #1 (permalink)
Old 01-24-2012, 06:34 PM
Junior Member
dbergquist is on a distinguished road
Default Whirlpool Cabrio getting F50 F51 fault codes
Model Number: WTW6400SW2   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool Cabrio is getting an F50 fault code when it attempts to spin. When I activate the auto diagnostic mode, F50 and F51 are indicated in the saved fault codes. The auto diagnostic fails at step C0 with an F50 fault code.
When I activate the manual motor test, the Wash, Rinse, and Spin indicators toggle as expected when I turn the basket. The manual spin test results again in an F50 fault code.
The basket spun freely, but went ahead and removed the basket from the tub and found a sock between them. Unfortunately, after removing the sock, I repeated the diagnostic tests above with the same results.
I then performed each of the steps in TEST #3. The P5 and P10 connectors passed continuity tests and were inserted correctly at both ends. The resistance between pins P10-1 and P10-7 was within the expected range, but the resistance between P5-1 and P5-2 and between P5-1 and P5-3 was 31.2 ohms rather than the 16 ohms indicated in the TEST #3 documentation.
I was going to replace the drive motor (stator) part number AP5306946, but in the Q&A on the part page a tech responding to one of the questions said the 31 ohms is the correct resistance for this part.
If the stator resistance is 31 ohm rather than 16, then my washer has passed every check in TEST #3. Can anyone confirm what the stator resistance should be? Is there anything else I should check? Any help would be greatly appreciated.
Related Models
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
Whirlpool WTW8800YW0 WASHER
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Maytag WU100 DISHWASHER- UNDERCOUNTER
Maytag WU1000 DISHWASHER- UNDERCOUNTER
Roper WU1000X0 Dishwasher
Roper WU1000X1 Dishwasher
Roper WU1000X4 Dishwasher
Roper WU1000X5 Dishwasher
Roper WU1000X6 Dishwasher
Roper WU1000X7 Dishwasher
Roper WU1000X8 Dishwasher
Roper WU1000Y0 UNDERCOUNTER DISHWASHER
Roper WU1000Y1 UNDERCOUNTER DISHWASHER
Maytag WU1004 DISHWASHER- UNDERCOUNTER
Maytag WU1005 DISHWASHER- UNDERCOUNTER
Maytag WU101 DISHWASHER- UNDERCOUNTER
Maytag WU103 DISHWASHER- UNDERCOUNTER
Maytag WU104 DISHWASHER- UNDERCOUNTER
Maytag WU180 DISHWASHER- UNDERCOUNTER
Roper WU1800XX0 Dishwasher
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 DISHWASHER- UNDERCOUNTER
Maytag WU200 DISHWASHER- UNDERCOUNTER
Maytag WU201 DISHWASHER- UNDERCOUNTER
Maytag WU202 DISHWASHER- UNDERCOUNTER
Maytag WU203 DISHWASHER- UNDERCOUNTER
Maytag WU204 DISHWASHER- UNDERCOUNTER
Maytag WU282 DISHWASHER- UNDERCOUNTER
Maytag WU284 DISHWASHER- UNDERCOUNTER
Maytag WU285 DISHWASHER- UNDERCOUNTER
Maytag WU300 DISHWASHER- UNDERCOUNTER
Roper WU3000V0 Dishwasher
Roper WU3000V1 Dishwasher
Roper WU3000V2 Dishwasher
Roper WU3000V3 Dishwasher
Roper WU3000X0 Dishwasher
Roper WU3000X1 Dishwasher
Roper WU3000X2 Dishwasher
Roper WU3000X3 Dishwasher
Roper WU3000X4 Dishwasher
Roper WU3000X5 Dishwasher
Roper WU3000X6 Dishwasher
Roper WU3000Y0 DISHWASHER
Roper WU3000Y1 UNDERCOUNTER DISHWASHER
Roper WU3006V0 Dishwasher
Roper WU3006V1 Dishwasher
Roper WU3006V2 Dishwasher
Roper WU3006V3 Dishwasher
Roper WU3006X0 Dishwasher
Roper WU3006X1 DISHWASHER
Roper WU3006X2 Dishwasher
Roper WU3006X3 Dishwasher
Roper WU3006X4 Dishwasher
Roper WU3006X5 Dishwasher
Roper WU3006X6 Dishwasher
  #2 (permalink)
Old 01-25-2012, 04:01 AM
Junior Member
tonystrachan is on a distinguished road
Default
l have the exact same washer with this exact problem. According to the documentation, the stator should be 31 ohms. What I don,t understand is why it is supposed to read 16 ohms at P5 (per test 3) and 31 ohms at the stator (per the repair manual). My machine reads 31 ohms at P5 and at the stator (makes sense with only wire between these two points). My understanding is the motor control board is the likely culprit at this point.
  #3 (permalink)
Old 01-27-2012, 06:36 PM
Junior Member
Default Problem solved
I purchased the control board (part number AP4360738) and the kit that contains the RPS board (part number AP4327312). I replaced the control board and re-ran the auto diagnostic test and it ran successfully this time. I didn't need the RPS board kit, but I'm going to keep it anyway because I figure I'll need it eventually.
I also took the opportunity to refurbish the cabinet top. I was surprised how rusted the underside of the cabinet top was. From the outside the washer looks almost new, but after 4 years of service there was a lot of rust on the underside so I wire-brushed and painted with white rustoleum primer. I also cleaned all the dispensers.
I just wanted to express my thanks to those who have contributed to this site. I couldn't have fixed this without your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cabrio Washer stops 1 min into cycle F-51 fault tvezdos Washer Repair 2 05-08-2012 06:52 PM
fault code for whirlpool cabrio washer tdross Washer Repair 10 07-31-2011 02:27 AM
Whirlpool oven fault codes E3 and F1 txtrisha Oven Repair (including Ranges and Cooktops) 0 02-08-2011 07:51 PM
F1-1, F1-2, F3-2 Fault Codes pjc97009 Oven Repair (including Ranges and Cooktops) 0 11-15-2010 01:47 PM
Kenmore/Whirlpool Fault Codes??? sgo529 Oven Repair (including Ranges and Cooktops) 3 11-05-2008 11:32 AM
