Discuss
Which grease type and brand for front loading washing machine shaft seal??
 in
Washer Repair
Guys, I'm in the middle of replacing a shaft seal for a Maytag front loading washing machine. The replacement seal
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Which grease type and brand for front loading washing machine shaft seal??
  #1 (permalink)
Old 01-23-2012, 12:40 PM
Junior Member
Bobbie51 is on a distinguished road
Default Which grease type and brand for front loading washing machine shaft seal??
Brand: -brand-   Age: Less than 1 year
Guys,
I'm in the middle of replacing a shaft seal for a Maytag front loading washing machine. The replacement seal and sleeve came with grease already applied to the sleeve but my helper mistakenly cleaned it up for me, discarding the factory grease. It was a red slightly tacky grease.
I know aluminum complex greases are often used due to their resistance to water washout.
Please guys, don't guess or tell me what you're grandpapy used for 30 years or to go to PepBoys to get wheel bearing grease, I'm looking for a technical answer specific to front loader washing machine shaft seals, if anyone out there knows.
bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Grease under Washing Machine jheissle Washer Repair 1 12-23-2011 02:35 PM
replace moldy gasket on LG front loading washing machine jack shannon Washer Repair 0 11-05-2011 07:40 AM
front loading washing machine inlet nozzle leaking manion Washer Repair 1 07-05-2011 02:17 PM
front loading washing machine door warped jterry10 Washer Repair 4 02-08-2010 07:36 PM
Washing Machine Leaks From Front Tab Seal konekwek Washer Repair 1 12-08-2008 02:53 PM
