Discuss
finding a direct drive washer
 in
Washer Repair
Hello folks. I'm in the market (sort of) for a new washing machine, and I read somewhere that direct drive
Appliance Repair Forum > Appliance Repair Help > Washer Repair » finding a direct drive washer
  #1 (permalink)
Old 07-14-2009, 06:19 PM
Junior Member
NCjohn is on a distinguished road
Default finding a direct drive washer
Brand: -brand-   Age: Less than 1 year
Hello folks.
I'm in the market (sort of) for a new washing machine, and I read somewhere that direct drive machines are the best from the standpoint of easier (cheaper) repairs. The sad fact seems to be that all home appliances these days are either sorry or sorrier, and the question isn't whether or not they'll have to be repaired, but rather how soon and how often. SO... I thought that direct drive seemed like a good choice.
However, I've looked at washers at lots of web sites (including manufacturers'), and haven't found a single site that stated in the machine specs that it was direct drive. How do I find this out?
Thanks.
  #2 (permalink)
Old 07-14-2009, 06:50 PM
Senior Member
applianceman is on a distinguished road
Default
Most Whirlpool washers are direct drive washers. If you post model numbers we can tell you for sure.
My opinion of these washers is that they break down more often than other brands but are most of the time easier and cheaper to repair. I donít think you could go wrong buying one they are good machines. Clothes Washer Repair Guide
  #3 (permalink)
Old 07-15-2009, 09:46 AM
Junior Member
Default
Well, I don't have a particular model in mind yet because I just started looking today.
But I have another question:
Why do they break down more often, and what makes them easier to repair?
Also, I've read more than once that the Whirlpools are a good choice but that they're extremely noisy in use. Any experience with regards to the noise?
Thanks very much.
  #4 (permalink)
Old 07-15-2009, 12:24 PM
Senior Member
Default
The reason I made that statement is because they have three parts that go bad often and those parts are easy to install (I can install any one of these three parts in less than 20 minutes) and relatively cheap. The lid switch, water pump and coupling are the parts that give the most trouble. 99% if the times when I work on a direct drive washer one of these parts are bad.
I am not by any means saying that if you buy this machine that one of these three parts will necessary go bad. Nor am I saying that these are the only parts that go bad. I am just speaking generally by my past experience
As for the noise they are not the quietest on the market but I donít see that they are necessary noisy washers.
  #5 (permalink)
Old 07-15-2009, 12:53 PM
Junior Member
Default
Okay, thanks for the reply. I'll be looking at some specific models and getting back to you to see if they're direct drive.
Thanks a lot.
  #6 (permalink)
Old 07-15-2009, 09:03 PM
Junior Member
Default
Well, I'm thinking about the WTW5100VQ. Apparently it's the bottom of the line, but the reviews about it seem to be pretty consistent, something I can't say about some others. If it's a direct-drive, I'll check it out further.
Thanks.
  #7 (permalink)
Old 07-16-2009, 06:16 AM
Senior Member
Default
Yes, it is a direct drive and if you donít care about all the bells and whistles buying the bottom of the line machine is not necessarily a bad thing.
  #8 (permalink)
Old 07-17-2009, 10:50 AM
Junior Member
Default
I assume the 5200 is also direct drive; the same machine with a couple extra options. Is that correct?
I looked in your web site's "parts" section to see if the wtw5200vq was listed, and it could only find wtw5200sq0. Will this be a problem if I need to buy parts?
I really appreciate your help with this.
  #9 (permalink)
Old 07-17-2009, 04:00 PM
Senior Member
Default
Yes, it also seems to be direct drive. I donít think you will have a problem getting parts for this machine but I do work for or own this website so I donít know for sure.
  #10 (permalink)
Old 09-02-2010, 05:47 PM
Junior Member
johnt7225 is on a distinguished road
Default
@NCjohn
What machine did you end up buying, and are you happy with it?
@applianceman
Are there any model that you recommend?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
direct drive washer cecil tillery Washer Repair 1 08-17-2009 06:35 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Direct drive washer brake yurman Washer Repair 1 08-02-2009 04:35 AM
Roper Washer Direct Drive Jennburch Washer Repair 2 11-28-2008 05:57 AM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 04:24 PM
