my washer has always just put the amount of water for the load size I had. Now no matter what size load, small, medium. or large it puts the same amount of water. it fills it all the way to the top before it starts the wash cycle.
Open up the console and blow out the tube that goes from the water level switch to the tub
If that does not fix things try changing out the water level switch.
