Discuss
Bosch washer- leaking at pump assembly
 in
Washer Repair
Washer is leaking. Initially noticed that the soap dispenser wasn't emptying, then found water on the floor. Leaking from
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bosch washer- leaking at pump assembly
  #1 (permalink)
Old 01-04-2008, 01:27 PM
PBroadfoot PBroadfoot is offline
Junior Member
PBroadfoot is on a distinguished road
Default Bosch washer- leaking at pump assembly
Model Number: WFK2401UC   Brand: Bosch   Age: 5 - 10 years
Washer is leaking. Initially noticed that the soap dispenser wasn't emptying, then found water on the floor. Leaking from the nipple on the pump housing (part # 265757). Loses c. 1/2 -1 cup per load of wash. Need to know if the problem would be in the pump and/or pump housing, or if this is an overflow which could be coming from another area that is getting backed up. This will be the 6th or 7th repair on this washer, so trying to decide whether it is worth the aggravation.
Thanks for any help or insights!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-18-2008, 09:12 PM
cdean cdean is offline
Junior Member
cdean is on a distinguished road
Default Same Problem
I have the same model and the same issues. I have been disapointed by this product. It needs a new control board and pump. I don't think I will buy another Bosch.
  #3 (permalink)
Old 01-19-2008, 08:57 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
electronics are covered by Bosch for 3 or 5 years ... pumps leak usually because grit gets in the threads of the filter. Clean out filter and wipe threads well and get out all grit and tighten filter into pump housing well... if the pump is leaking and it is under 4-5 years old, you are probably using TOO MUCH detergent!!!
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer belt/pump dpm6264 Washer Repair 1 11-03-2007 10:05 AM
Is it the Washer Pump aorose Washer Repair 1 10-27-2007 11:01 AM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 01:22 PM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
Removing pump motor assembly dcherioke1 Dishwasher Repair 1 09-14-2007 11:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
