Discuss
Whirlpool top loader leaks, not sure if it will spin
 in
Washer Repair
So my front loader Frigidaire finally broke down after 6 years, spider was cracked and it is too expensive for
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool top loader leaks, not sure if it will spin
  #1 (permalink)
Old 01-16-2012, 07:10 PM
Junior Member
OP4500 is on a distinguished road
Default Whirlpool top loader leaks, not sure if it will spin
Model Number: 4217141   Brand: Estate   Age: More than 10 years
So my front loader Frigidaire finally broke down after 6 years, spider was cracked and it is too expensive for me to replace, so I picked up an untested estate by whirlpool top loader for $40 at a thrift store. When I start the cycle it begins filling and then leaks from the water pump. The water pump is a cheap, easy fix so I don't mind replacing that, but I'm not sure if this thing will even spin. I tried turning the knob to various points and it will either fill or do nothing. Should it spin? or will it not spin until it reaches a certain water level? If the motor or coupling is bad I'm probably just going to take it back. How can I test the spin cycle without filling it up?
Ads By Google
Related Models
Amana 425.0 Mwave - Family Size (60 Hz)
Amana 425.000 Mwave - Family Size (60 Hz)
Amana 425.001 Mwave - Family Size (60 Hz)
Magic Chef 4251WRA Range - F/s Cont Clean Gas
Magic Chef 4251WRW Range - F/s Cont Clean Gas
Magic Chef 4251WTA Range - F/s Cont Clean Gas
Magic Chef 4251WTW Range - F/s Cont Clean Gas
Amana 426.000 Mwave - Family Size (60 Hz)
Magic Chef 42GA-7 Range - F/s Cont Clean Gas
Magic Chef 42GN-7 Range - F/s Cont Clean Gas
Hoover 434 Frigidaire/refrigerator
Frigidaire 44-2401-00-01 Tap(v1) / 24 " Laundry Center
Frigidaire 44-2401-23-01 Tap(v2) / 24 " Laundry Center
Frigidaire 44-2407-00-01 Tap(v1)
Frigidaire 44-2407-00-02 Tap(v3)
Frigidaire 44-2407-00-03 Tap(v1) / Laundry Center
Frigidaire 44-2407-23-01 Tap(v2)
Frigidaire 44-2407-23-02 Tap(v4)
Frigidaire 44-2407-23-03 Tap(v2) / Laundry Center
Frigidaire 44-2408-00-01 Tap(v1) / Laundry Center
Frigidaire 44-2408-00-03 Tap(v1) / Laundry Center
Frigidaire 44-2408-23-01 Tap(v2) / Laundry Center
Frigidaire 44-2408-23-03 Tap(v2) / Laundry Center
Frigidaire 44-2409-00-01 Tap(v1) / 24 " Laundry Center
Frigidaire 44-2409-00-02 Tap(v1) / 24 " Laundry Center
Frigidaire 44-2409-23-01 Tap(v2) / 24 " Laundry Center
Frigidaire 44-2409-23-02 Tap(v2) / 24 " Laundry Center
Frigidaire 44-2417-00-01 Tap(v1) / Laundry Center
Frigidaire 44-2417-23-01 Tap(v2) / Laundry Center
Hoover 444 Frigidaire/refrigerator
Amana 445.000 Mwave - Family Size (60 Hz)
Hoover 454
Amana 455.000 Mwave - Family Size (60 Hz)
Magic Chef 45EA-2W Range - F/s Std Ele
Magic Chef 45EA-3CLW Range - F/s Cont Clean Ele
Magic Chef 45EB-3CLW Range - F/s Cont Clean Ele
Magic Chef 45EG-3CLW Range - F/s Cont Clean Ele
Magic Chef 45EN-2W Range - F/s Std Ele
Magic Chef 45EN-3CLW Range - F/s Cont Clean Ele
Magic Chef 45EY-2W Range - F/s Std Ele
Magic Chef 45EY-3CLW Range - F/s Cont Clean Ele
Frigidaire 46-2151-00-01 Tap(v1) / 27 " Washer
Frigidaire 46-2151-23-01 Tap(v2) / 27 " Washer
Frigidaire 46-2251-00-01 Tap(v3) / 27 " Washer
Frigidaire 46-2251-00-03 Tap(v1) / 27 " Washer
Frigidaire 46-2251-23-01 Tap(v4) / 27 " Washer
Frigidaire 46-2251-23-03 Tap(v2) / 27 " Washer
Frigidaire 46-2351-00-01 Tap(v1) / 27 " Washer
Frigidaire 46-2351-00-02 Tap(v1) / 27 " Washer
Frigidaire 46-2351-23-01 Tap(v2) / 27 " Washer
Frigidaire 46-2351-23-02 Tap(v2) / 27 " Washer
Frigidaire 46-2451-00-01 Tap(v1) / 27 " Washer
Frigidaire 46-2451-23-01 Tap(v2) / 27 " Washer
Frigidaire 46-2551-00-01 Tap(v5) / 27 " Washer
Frigidaire 46-2551-00-02 Tap(v3) / 27 " Washer
Frigidaire 46-2551-23-01 Tap(v6) / 27 " Washer
Frigidaire 46-2551-23-02 Tap(v4) / 27 " Washer
Frigidaire 46-2651-00-01 Tap(v3) / 27 " Washer
Frigidaire 46-2651-00-02 Tap(v1) / 27 " Washer
Frigidaire 46-2651-23-01 Tap(v4) / 27 " Washer
Frigidaire 46-2651-23-02 Tap(v2) / 27 " Washer
Frigidaire 46-2707-00-00 Tap(v2)
Frigidaire 46-2707-23-00 Tap(v1)
Frigidaire 46-2751-00-01 Tap(v1) / 27 " Washer
Frigidaire 46-2751-23-01 Tap(v2) / 27 " Washer
Frigidaire 46-2810-00-01 Tap(v5) / 27 " Washer
Frigidaire 46-2810-23-01 Tap(v6) / 27 " Washer
Frigidaire 46-2810-66-02 Tap(v3) / 27 " Washer
Frigidaire 46-2817-00-01 Tap(v1) / Top Loading Washer
Frigidaire 46-2817-00-02 Tap(v2) / Washer
Frigidaire 46-2817-00-05 Tap(v1) / Top Load Washer
Frigidaire 46-2817-23-01 Tap(v2) / Top Loading Washer
Frigidaire 46-2817-23-02 Tap(v1) / Washer
Frigidaire 46-2817-23-05 Tap(v2) / Top Load Washer
Frigidaire 46-2830-00-01 Tap(v3) / 27 " Washer
Frigidaire 46-2830-23-01 Tap(v4) / 27 " Washer
Frigidaire 46-2830-23-02 Tap(v2) / 27 " Washer
Frigidaire 46-2837-00-01 Tap(v3) / Top Loading Washer
Frigidaire 46-2837-00-02 Tap(v4) / Washer
Frigidaire 46-2837-00-05 Tap(v3) / Top Load Washer
Frigidaire 46-2837-23-01 Tap(v4) / Top Loading Washer
Frigidaire 46-2837-23-02 Tap(v3) / Washer
Frigidaire 46-2837-23-05 Tap(v4) / Top Load Washer
Frigidaire 46-2850-00-01 Tap(v1) / 27 " Washer
Frigidaire 46-2850-00-02 Tap(v1) / 27 " Washer
Frigidaire 46-2850-23-01 Tap(v2) / 27 " Washer
Frigidaire 46-2857-00-01 Tap(v5) / Top Loading Washer
Frigidaire 46-2857-00-02 Tap(v6) / Washer
Frigidaire 46-2857-00-05 Tap(v5) / Top Load Washer
Frigidaire 46-2857-23-01 Tap(v6) / Top Loading Washer
Frigidaire 46-2857-23-02 Tap(v5) / Washer
Frigidaire 46-2857-23-05 Tap(v6) / Top Load Washer
Amana 460.000 Mwave - Family Size (60 Hz)
Amana 460.001 Mwave - Family Size (60 Hz)
Amana 465.000 Mwave - Family Size (60 Hz)
Frigidaire 47-2151-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-00-02 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2151-23-02 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-02 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-00-05 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-02 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-23-05 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2351-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2351-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2451-00-01 Tap(v5) / 27 " Electric Dryer
Frigidaire 47-2451-00-03 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-23-01 Tap(v6) / 27 " Electric Dryer
Frigidaire 47-2451-23-03 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2451-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2551-00-03 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-23-03 Tap(v2) / 27 " Electric Dryer
  #2 (permalink)
Old 01-18-2012, 05:35 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If you put the timer on spin it will spin without filling up. I would guess the coupling is broken, and it is a less expensive repair than the pump. Pull the pump and motor and check the coupling. If the machine will work with a pump and coupling repair you got a good deal, go with it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front loader won't spin mole65 Washer Repair 1 08-17-2011 01:34 PM
Front loader won't spin msappington Washer Repair 1 03-21-2010 11:39 AM
Whirlpool front loader ont drain and spin gaffneytigger Washer Repair 2 01-08-2010 05:02 AM
Frigidaire front loader door leaks tonim Washer Repair 4 03-30-2008 04:38 AM
